[GRASS-dev] [GRASS GIS] #424: AC_CONFIG_AUX_DIR added in configure.in of 6.4.x causes rpmbuild failure
Reporter: neteler | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: 6.4.0 RCs
Keywords: | Platform: Linux
      Cpu: All |
The following addition to configure.in of 6.4.x:
diff -u ~/grass63_release/configure.in configure.in
--- /home/neteler/grass63_release/configure.in 2008-03-26
16:04:27.000000000 +0100
+++ configure.in 2008-09-12 23:02:45.000000000 +0200
@@ -99,6 +99,10 @@
  AC_SUBST(ARCH)
+# Use absolute path for aux directory so that install-sh works
+AC_CONFIG_AUX_DIR($SRCDIR)
  # Set GISBASE and GRASS_BIN
  GISBASE=${WINDSTDIR}/dist.${ARCH}
leads to this error when creating a (Mandriva) RPM from 6.4.0RC1:
rpmbuild -ba grass640RC1.specExecuting(%prep): /bin/sh -e /var/tmp/rpm-
tmp.40668
+ umask 022
+ cd /usr/src/rpm/BUILD
+ LDFLAGS='-L/usr/X11R6/lib64 -Wl,--as-needed -Wl,--no-undefined'
+ export LDFLAGS
+ CONFIGURE_TOP=.
+ /usr/lib/rpm/manbo/force-as-needed-for-shared-lib-in-libtool
Forcing -Wl,--as-needed in configure/libtool to workaround libtool bug (cf
http://lists.gnu.org/archive/html/libtool-patches/2004-06/msg00002.html)
+ /usr/lib/rpm/manbo/drop-ld-no-undefined-for-shared-lib-modules-in-
libtool
+ cputoolize -c .
libtoolize: cannot handle variables in AC_CONFIG_AUX_DIR
error: Bad exit status from /var/tmp/rpm-tmp.16786 (%build)
RPM build errors:
Do we really need AC_CONFIG_AUX_DIR (e.g., in GRASS 6.3 it wasn't needed)
or can it be conditionalized?
Ticket URL: <http://trac.osgeo.org/grass/ticket/424&gt;
Resolution: | Keywords:
  Platform: Linux | Cpu: All
Comment (by neteler):
It was added in r32168
Ticket URL: <http://trac.osgeo.org/grass/ticket/424#comment:1&gt;
Comment (by glynn):
Replying to [ticket:424 neteler]:
> + cputoolize -c .
This looks like a problem with the RPM spec file. GRASS doesn't use
libtool. The build process shouldn't be concerning itself with the
contents of those scripts, just running configure.
needed) or can it be conditionalized?
It's needed, and I don't think that it can be conditionalised.
Ticket URL: <http://trac.osgeo.org/grass/ticket/424#comment:2&gt;
      Type: defect | Status: closed
Resolution: wontfix | Keywords:
Changes (by neteler):
  * status: new => closed
  * resolution: => wontfix
Comment:
Replying to [comment:2 glynn]:
OK, changing in the SPEC file
%configure
to
./configure
works around the problem since libtool(ize) is then not used.
Ticket URL: <http://trac.osgeo.org/grass/ticket/424#comment:3&gt;
