#433: Enable (de)selection of map layers in workspace via CTRL or Shift
Reporter: epatton | Owner: grass-dev@lists.osgeo.org
Priority: trivial | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Keywords: workspace, layer, selection | Platform: Linux
Cpu: x86-64 |
In the wxgui, one can add a subset of a mapset's map layers to a workspace
by using a wildcard search pattern; it would be useful to be able to use
the CTRL and/or Shift keys to make more precise selections, where the
desired maps do not conform to some common naming convention.
Resolution: | Keywords: workspace, layer, selection
Platform: Linux | Cpu: x86-64
Comment (by epatton):
Thinking about it a little more, it's just as easy to click the checkbox
next to each map rather than use the Control key; but it would be useful
to use the Control key in combination with the Shift key to make multiple
selections of *blocks* of map layers to load at once.
