#443: cairo driver: labels are not rendered
Reporter: martinl | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 7.0.0
Component: Display | Version: svn-trunk
Keywords: cairo | Platform: All
Cpu: All |
Cairo driver does not display any labels (PNG driver seems to work). E.g.
Component: Display | Version: 6.4.0 RCs
Resolution: | Keywords: cairo
Platform: All | Cpu: All
Changes (by mmetz):
* version: svn-trunk => 6.4.0 RCs
Comment:
In the North Carolina dataset,
d.vect boundary_county attrcol=NAME
doesn't work for me nowhere, from 6.4.0RC5 through to 7, any display
driver. In 7, I can't even give an attrcol, that option in the wxGUI
behaves as if it's disabled.
Comment (by hamish):
Replying to [comment:2 mmetz]:
> d.vect boundary_county display=shape,cat
> works.
> Applies to wxGUI only, not to tcltk.
the above example is missing disp=attr
e.g., works in 6.5 xmon:
{{{ #spearfish
d.vect archsites disp=attr attrcol=str1
perhaps (attrcol->answer != NULL) should switch on disp=attr if it was not
already given??
Comment (by mmetz):
Replying to [comment:3 hamish]:
Hmph. Sorry for the noise, everything is fine. Except grass7, still can't
set option attrcol, also when setting disp=attr first.
not already given??
Maybe you want the column to be remembered but temporarily switch off
label display?
Reporter: martinl | Owner: grass-dev@…
Cpu: All |
Comment(by neteler):
Replying to [ticket:443 martinl]:
E.g.
> d.vect map=geodetic_swwake_pts@PERMANENT display=shape,cat
