#446: put user and machine name into .gislock file
Reporter: benducke | Owner: grass-dev@lists.osgeo.org
Priority: minor | Milestone: 6.4.0
Component: default | Version: svn-trunk
Keywords: locking, .gislock | Platform: All
Cpu: Unspecified |
If a .gislock file gets created for a user, then it might be a good idea
to store that user's current login name and machine name in the file. That
way, external GUIs that encounter a lockfile when trying to log a user
into a mapset will be able to output a more specific error message,
including the lockfile creator's identity, giving the user a better clue
as to whether the lockfile can be safely deleted or not.
Not sure what version of GRASS this could go into, but it seems to me it
would not affect any of the current functionality(?).
Resolution: | Keywords: locking, .gislock
Platform: All | Cpu: Unspecified
Comment (by hamish):
there is a good chance that the lock file was created by you on the local
machine. so perhaps it would be good to also log the lock file creation
time as an indicator of how stale the file is. (or check file creation
time if that is portable)
I am a bit unsure if this should really be targeted for grass 6.4 or only
go into grass 7. I understand waiting for grass 7 is unpleasant for QGIS,
but we must protect the stable branch.... if for grass64 we must ensure
backwards compatibility with other grass 6.[0-3].
Comment (by glynn):
Replying to [ticket:446 benducke]:
The machine name should go into the file. At present, etc/lock reads the
PID and checks whether the process is still running. Obviously, this only
works if the creator process is running on the same system as the checking
process.
Also, the current format is an "int" in the platform's native format, so
you can't even report the PID correctly if it was written using a
different byte order (or sizeof(int)).
lib/init/lock.c should at least check that PID is positive before checking
for existence.
It can't go into 6.x, as existing versions of GRASS won't understand the
new format, and in the case where the database is shared via NFS, you
can't assume that all systems are using the same version of GRASS.
Reporter: benducke | Owner: grass-dev@…
Priority: minor | Milestone: 7.0.0
Component: LibGIS | Version: svn-trunk
Cpu: Unspecified |
Comment(by wenzeslaus):
According to [http://semver.org/ semantic versioning], ''pre-release
versions have a lower precedence than the associated normal version. A
pre-release version indicates that the version is unstable and might not
satisfy the intended compatibility requirements as denoted by its
associated normal version,'' And we are not yet released 7.x. So, if we
are still adding minor features to release branch, the rules allows us to
add this if it is not too dangerous (I cannot tell) or it is very
important.
Cpu: Unspecified |
Comment(by neteler):
Let's get it implemented now if we want to see it in GRASS 7... the last
beta is being prepared.
