[GRASS-dev] [GRASS GIS] #461: v.to.db crashes on a shapefile connected with v.external
  Reporter: msieczka | Owner: grass-dev@…
      Type: defect | Status: closed
  Priority: major | Milestone: 7.0.7
Component: Vector | Version: svn-trunk
Resolution: fixed | Keywords: v.external, v.to.db
       CPU: x86-64 | Platform: Linux
Changes (by martinl):
* status: new => closed
* resolution: => fixed
Old description:
Backtrace:
GRASS 6.5.svn (javier):~ > gdb v.to.db
GNU gdb 6.8-debian
Copyright (C) 2008 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later
<http://gnu.org/licenses/gpl.html&gt;
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law. Type "show
copying"
and "show warranty" for details.
This GDB was configured as "x86_64-linux-gnu"...
(gdb) run map=gshhs_shp opt=area units=k col=AREA
Starting program: /usr/local/grass-6.5.svn/bin/v.to.db map=gshhs_shp
[Thread debugging using libthread_db enabled]
warning: Lowest section in /usr/lib/libicudata.so.38 is .hash at
0000000000000120
[New Thread 0x7fe8946c9710 (LWP 9814)]
Reading areas...
100%
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0x7fe8946c9710 (LWP 9814)]
0x00007fe89418f539 in db_get_column_sqltype (column=0x0) at column.c:107
107 return column->sqlDataType;
(gdb) bt
#0 0x00007fe89418f539 in db_get_column_sqltype (column=0x0) at
column.c:107
#1 0x00007fe8938f480d in db_select_int (driver=0x9237ba0, tab=0x98bb7f0
"gshhs", col=0x98b8ba0 "", where=0x0, pval=0x7fff9c7ff858) at
select.c:138
#2 0x00000000004069f2 in update (Map=0x7fff9c7ff8c0) at update.c:53
#3 0x00000000004043e4 in main (argc=5, argv=0x7fff9c7fffd8) at main.c:84
New description:
Backtrace:
GNU gdb 6.8-debian
There is NO WARRANTY, to the extent permitted by law. Type "show copying"
https://trac.osgeo.org/grass/ticket/461#no3&quot;x86\_64\-linux\-gnu&quot;\.\.\.
0000000000000120
Reading areas...
  100%
(gdb) bt
column.c:107
"gshhs", col=0x98b8ba0 "", where=0x0, pval=0x7fff9c7ff858) at select.c:138
Comment:
Originally reported bug seems to be fixed. Free free to reopen if needed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/461#comment:18&gt;
