[GRASS-dev] [GRASS GIS] #463: Display error in wxdigit
Reporter: Vincent | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: minor | Milestone: 6.4.0
Component: wxGUI | Version: unspecified
Keywords: digitize,areas,fill color | Platform: Unspecified
      Cpu: Unspecified |
A little defect in the display when digitizing a vector map containing
areas:
areas (ie boundary+centroid) should appear with a fill color.
If a boundary defines an island:
    * it turns filled (always in white, noticeable with a b.g. raster)
eventhough not provided with a centroid, when the surrounding area is
defined;
    * adding a centroid to make it an actual area, it remains white (not
the color set for areas).
In the case of polygons void of centroids, completely surrounded by areas
(not really islands, but let's say "holes"), the problem does not arise.
Vincent
Ticket URL: <http://trac.osgeo.org/grass/ticket/463&gt;
Reporter: Vincent | Owner: grass-dev@…
Priority: minor | Milestone: 6.4.2
      Cpu: Unspecified |
Changes (by neteler):
  * milestone: 6.4.0 => 6.4.2
Comment:
Is this still an issue in the current 6.4.svn wxdigitizer?
Ticket URL: <http://trac.osgeo.org/grass/ticket/463#comment:1&gt;
