#47: NVIZ load 3D settings (3d.view) issues
Reporter: marisn | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: minor | Milestone: 6.4.0
Component: default | Version: svn-trunk
Keywords: nviz |
As 3d settings (3d.view) loading crash is fixed in current svn-trunk, here
is a list of things, that are not yet solved:[[BR]]
* height is not set to 3d.view file value (see more here #45);[[BR]]
* MESH_FREQ, POLY_RES are ignored;[[BR]]
* Light related param's are ignored;[[BR]]
* Loading doesn't use GRASS standart select 3d.view dialog. Same goes for
save 3d settings.[[BR]]
Probably I have missed some more issue.
