#476: Map Display Window position does not remember saved position settings
Reporter: epatton | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: minor | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Keywords: | Platform: Linux
Cpu: x86-64 |
In 6.4 develbranch6, the Map Display window does not honor the saved
position or size settings, although the GIS Layer Manager does. See
attached screenshots for ideal window positions (i.e. the position of all
windows when I check the box 'Save current window layout as default in the
wxgui) vs. the actual window positions when I subsequently resume a Grass
session.
Reporter: epatton | Owner: martinl
Type: defect | Status: assigned
Resolution: | Keywords:
Platform: Linux | Cpu: x86-64
Comment (by martinl):
Replying to [comment:2 epatton]:
> Hmm, after a make distclean and svn up today, the problem seems to
persist, whether I click 'Apply' or 'Save'; see today's screenshot.
Which version? Testing grass65 (devbr6).
1. start GRASS, grass65 -wxpython
1. Go to preferences and check in "Save ..."
1. Change windows position (and dimension)
1. Click "Save" in preferences dialog
1. Quit wxGUI
1. Restart wxGUI, g.gui wxpython &
