[GRASS-dev] [GRASS GIS] #479: wxgui mapset access module broken
Reporter: cmbarton | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 6.5.0
Component: wxGUI | Version: svn-develbranch6
Keywords: g.mapsets | Platform: Unspecified
      Cpu: Unspecified |
Trying to use the wxPython module to set mapset access raises an error in
develbranch_6 compiled today from the SVN. I'm guessing that this is the
same across 6.4 and 7. Here is the error as tested on the Spearfish
PERMANENT location.
PERMANENT spatialtech2008 test1 test2 test3 user1
   File "/Applications/Grass/GRASS-6.5.app/Contents/MacOS/etc
/wxpython/wxgui.py", line 363, in OnMapsets
dlg = preferences.MapsetAccess(parent=self, id=wx.ID_ANY)
/wxpython/gui_modules/preferences.py", line 1736, in
__init__
self.mapsetlb.LoadData()
/wxpython/gui_modules/preferences.py", line 1815, in
LoadData
stat_info = os.stat(mapsetPath)
OSError
[Errno 2] No such file or directory:
'/Users/Shared/grassdata/spearfish60_test/PERMANENT
spatialtech2008 test1 test2 test3 user1 '
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/479&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: g.mapsets
  Platform: Unspecified | Cpu: Unspecified
Changes (by cmbarton):
  * status: new => closed
  * resolution: => fixed
Comment:
Fixed in r35797 for develbranch_6 and backported to trunk and release
branch.
Ticket URL: <http://trac.osgeo.org/grass/ticket/479#comment:1&gt;
