[GRASS-dev] [GRASS GIS] #480: wx NVIZ prints debug info to terminal
Reporter: msieczka | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Keywords: | Platform: All
      Cpu: All |
For example:
GRASS_INFO_MESSAGE(20400,1): Ładuję mapę rastrową
<rogow_parcels_06_lndrcl_clt03@wlasnosc>...
GRASS_INFO_END(20400,1)
GRASS_INFO_PERCENT: 0
GRASS_INFO_PERCENT: 3
GRASS_INFO_PERCENT: 6
GRASS_INFO_PERCENT: 9
GRASS_INFO_PERCENT: 12
GRASS_INFO_PERCENT: 15
GRASS_INFO_PERCENT: 18
GRASS_INFO_PERCENT: 21
GRASS_INFO_PERCENT: 24
GRASS_INFO_PERCENT: 27
GRASS_INFO_PERCENT: 30
GRASS_INFO_PERCENT: 33
GRASS_INFO_PERCENT: 36
GRASS_INFO_PERCENT: 39
GRASS_INFO_PERCENT: 42
GRASS_INFO_PERCENT: 45
GRASS_INFO_PERCENT: 48
GRASS_INFO_PERCENT: 51
GRASS_INFO_PERCENT: 54
GRASS_INFO_PERCENT: 57
GRASS_INFO_PERCENT: 60
GRASS_INFO_PERCENT: 63
GRASS_INFO_PERCENT: 66
GRASS_INFO_PERCENT: 69
GRASS_INFO_PERCENT: 72
GRASS_INFO_PERCENT: 75
GRASS_INFO_PERCENT: 78
GRASS_INFO_PERCENT: 81
GRASS_INFO_PERCENT: 84
GRASS_INFO_PERCENT: 87
GRASS_INFO_PERCENT: 90
GRASS_INFO_PERCENT: 93
GRASS_INFO_PERCENT: 96
GRASS_INFO_PERCENT: 99
Ticket URL: <http://trac.osgeo.org/grass/ticket/480&gt;
  Reporter: msieczka | Owner: martinl
      Type: defect | Status: assigned
  Priority: major | Milestone: 6.5.0
Resolution: | Keywords:
  Platform: All | Cpu: All
Changes (by martinl):
  * status: new => assigned
  * owner: grass-dev@lists.osgeo.org => martinl
* cc: grass-dev@lists.osgeo.org (added)
  * milestone: 6.4.0 => 6.5.0
Comment:
This is long-standing issue (also for wxvdigit extension). "Fixed" in
relbr64 (r35805) - verbosity set to "0" (no messages). Milestone moved to
6.5.0.
Ticket URL: <http://trac.osgeo.org/grass/ticket/480#comment:1&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
  * status: assigned => closed
  * resolution: => fixed
Ticket URL: <http://trac.osgeo.org/grass/ticket/480#comment:2&gt;
      Type: defect | Status: reopened
  Priority: normal | Milestone: 6.4.2
Component: wxGUI | Version: svn-releasebranch64
Changes (by cmbarton):
  * priority: major => normal
  * status: closed => reopened
  * version: svn-develbranch6 => svn-releasebranch64
  * resolution: fixed =>
  * milestone: 6.5.0 => 6.4.2
Comment:
This is happening again in GRASS 6.4.2 svn. Fixed in trunk.
Ticket URL: <http://trac.osgeo.org/grass/ticket/480#comment:3&gt;
Comment(by martinl):
Replying to [comment:3 cmbarton]:
The wxNviz code in trunk quite differs from the code in relbr64. I would
postpone it for 6.4.3 which could come with newer version of wxNviz.
Ticket URL: <http://trac.osgeo.org/grass/ticket/480#comment:4&gt;
Resolution: | Keywords: wxNviz
  * keywords: => wxNviz
Ticket URL: <http://trac.osgeo.org/grass/ticket/480#comment:5&gt;
Comment(by cmbarton):
From the discussion, it looked like these messages had been turned off in
6.4 but somehow got turned back on again. Not worth a big investment of
time if difficult to do since wxNVIZ is not compiled by default in 6.x.
Ticket URL: <http://trac.osgeo.org/grass/ticket/480#comment:6&gt;
Replying to [comment:6 cmbarton]:
in 6.4 but somehow got turned back on again. Not worth a big investment of
There is nothing to compile, it's Python code only.
Ticket URL: <http://trac.osgeo.org/grass/ticket/480#comment:7&gt;
  Priority: normal | Milestone: 6.4.3
  * milestone: 6.4.2 => 6.4.3
Ticket URL: <http://trac.osgeo.org/grass/ticket/480#comment:8&gt;
Resolution: fixed | Keywords: wxNviz
  * status: reopened => closed
Comment:
Solved in recent version of wxNviz.
Ticket URL: <http://trac.osgeo.org/grass/ticket/480#comment:9&gt;
