[GRASS-dev] [GRASS GIS] #483: "return to previous zoom" brakes "zoom to selected map"
Reporter: msieczka | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Keywords: | Platform: Linux
      Cpu: x86-64 |
1. on the terminal set the region to a subset of the raster map you will
load in step 3
2. start wxGUI
3. add a raster map
4. "zoom to selected map"
5. query the map several times
6. "return to previous zoom" - the view changes to the region from step 1
7. query the map several times again
8. try "zoom to selected map" - the view fails to change
FWIW, while I was fiddling with querying and zooming the whole gui crashed
once, leaving a trace in dmesg:
[30891.603698] python[22007]: segfault at 2d56470 ip 2d56470 sp
7fff3623cb58 error 15
Ticket URL: <http://trac.osgeo.org/grass/ticket/483&gt;
  Reporter: msieczka | Owner: martinl
      Type: defect | Status: assigned
Resolution: | Keywords: raster querying
  Platform: Linux | Cpu: x86-64
Changes (by martinl):
* cc: grass-dev@lists.osgeo.org (added)
  * keywords: => raster querying
  * status: new => assigned
  * owner: grass-dev@lists.osgeo.org => martinl
Comment:
Please try r38334.
Ticket URL: <http://trac.osgeo.org/grass/ticket/483#comment:1&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: raster querying
  * status: assigned => closed
  * resolution: => fixed
Ticket URL: <http://trac.osgeo.org/grass/ticket/483#comment:2&gt;
