#484: Cannot reload maps to wxnviz
Reporter: cmbarton | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.5.0
Component: wxGUI | Version: svn-develbranch6
Keywords: wxnviz | Platform: MacOSX
Cpu: OSX/Intel |
This has always been a problem, but I haven't reported it because there
were other issues to fix in the new wxnviz. But now that it is getting so
much better otherwise, I guess it's time to get a track ticket on this.
I open maps and switch to 3D mode and everything looks and works fine. I
exit 3D mode successfully. No errors are reported during 3D mode or on
exiting.
I try to go back to 3D mode with the same maps and same display and the 3D
interface does not respond or does not respond correctly, and 3D maps are
not displayed or not displayed correctly (e.g., displayed without color
and only while moving the puck; then the map disappears). I get error
messages in the terminal and console. I'm pretty sure that this is linked
to an error I reported earlier with a failure to load any maps 2nd time
around (track #445). Here are the detailed error messages.
Terminal message
<Error>: CGContextRestoreGState: invalid context
Layer manager console message
Nviz:Raster map <elevation.10m@PERMANENT> unloaded successfully
Nviz:Loading failed
Nviz:Loading raster map <elevation.10m@PERMANENT> failed
Nviz:Loading failed
File "/Applications/Grass/GRASS-6.5.app/Contents/MacOS/etc
/wxpython/gui_modules/nviz_mapdisp.py", line 971, in
UpdateMapObjProperties
id = data['surface']['object']['id']
KeyError
'object'
KeyError
'object'
KeyError
'object'
KeyError
'object'
Ticket URL: <http://trac.osgeo.org/grass/ticket/484>
