#485: r.external crash
Reporter: hellik | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Raster | Version: 6.4.0 RCs
Keywords: | Platform: MSWindows Vista
Cpu: Unspecified |
osgeo4w (2008/02/08):
grass64rc3-2
GDAL 1.5.4, released 2009/01/07
gisdemo_ncspm-data:
r.out.gdal input=elevation@PERMANENT
output=C:\wd\testdata\demout.tif
=> export ok
info about demout.tif
gdalinfo demout.tif
Driver: GTiff/GeoTIFF
Files: demout.tif
Size is 1500, 1350
Coordinate System is:
PROJCS["Lambert Conformal Conic",
GEOGCS["NAD83",
DATUM["North_American_Datum_1983",
SPHEROID["GRS 1980",6378137,298.2572221010002,
AUTHORITY["EPSG","7019"]],
AUTHORITY["EPSG","6269"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4269"]],
PROJECTION["Lambert_Conformal_Conic_2SP"],
PARAMETER["standard_parallel_1",36.16666666666666],
PARAMETER["standard_parallel_2",34.33333333333334],
PARAMETER["latitude_of_origin",33.75],
PARAMETER["central_meridian",-79],
PARAMETER["false_easting",609601.22],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]]]
Origin = (630000.000000000000000,228500.000000000000000)
Pixel Size = (10.000000000000000,-10.000000000000000)
Metadata:
AREA_OR_POINT=Area
Image Structure Metadata:
INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( 630000.000, 228500.000) ( 78d46'27.41"W, 35d48'34.59"N)
Lower Left ( 630000.000, 215000.000) ( 78d46'28.63"W, 35d41'16.54"N)
Upper Right ( 645000.000, 228500.000) ( 78d36'29.89"W, 35d48'33.08"N)
Lower Right ( 645000.000, 215000.000) ( 78d36'32.01"W, 35d41'15.03"N)
Center ( 637500.000, 221750.000) ( 78d41'29.49"W, 35d44'54.91"N)
Band 1 Block=1500x1 Type=Float32, ColorInterp=Gray
Metadata:
COLOR_TABLE_RULES_COUNT=5
COLOR_TABLE_RULE_RGB_0=5.557879e+001 7.572901e+001 0 191 191 0 255 0
COLOR_TABLE_RULE_RGB_1=7.572901e+001 9.587922e+001 0 255 0 255 255 0
COLOR_TABLE_RULE_RGB_2=9.587922e+001 1.160294e+002 255 255 0 255 127 0
COLOR_TABLE_RULE_RGB_3=1.160294e+002 1.361797e+002 255 127 0 191 127
63
COLOR_TABLE_RULE_RGB_4=1.361797e+002 1.563299e+002 191 127 63 20 20 20
=> demout.tif ok
link external raster via gdal
r.external --verbose input=C:\wd\testdata\demout.tif output=demext
title=TestExternalLink
=> r.external-crash
I've tried the example above with wxpython- and tcltk-gui, in both cases
r.external crashes
Ticket URL: <http://trac.osgeo.org/grass/ticket/485>
