#489: g.setproj: sets proj info with missing UTM zone
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: minor | Milestone: 6.4.0
Component: default | Version: 6.4.0 RCs
Keywords: g.setproj | Platform: Linux
Cpu: x86-32 |
with g.setproj it is possible to set the region so that the resulting
PROJ_INFO file is missing the zone: field. Perhaps
this is because 'g.region -p' says the zone is -55 while g.proj
had 55(S)?
G640rc2> g.setproj
Would you still like to change some of the parameters?(y/n) [n] y
WARNING: Zone in default geographic region definition: -55
is different from zone in PROJ_INFO file: 55
Please specify projection name
>utm
[ do we want a space after the '>' prompt? ]
Do you wish to specify a geodetic datum for this location?(y/n) [y] y
Please specify datum name
>custom
[I did want the datum to be Australia GD 1994, but that's not a choice]
Please specify ellipsoid name
>grs80
Please specify datum transformation parameters
>towgs84=0,0,0
Parameters to be used are:
"towgs84=0,0,0"
Is this correct?(y/n) [y] y
South Hemisphere(y/n) [n] y
The UTM zone is now set to 55
Do you want to change the UTM zone?(y/n) [n] n
UTM zone information has not been updated
Projection information has been recorded for this location
then
g.proj -p
-PROJ_INFO-------------------------------------------------
name : Universe Transverse Mercator
towgs84 : 0,0,0
proj : utm
ellps : grs80
a : 6378137.0000000000
es : 0.0066943800
f : 298.2572221010
south : defined
-PROJ_UNITS------------------------------------------------
unit : meter
units : meters
meters : 1.0
and then r.in.gdal segfaults when attempting the matching proj settings
comparison. (strcmp() missing key value in lib/gis/make_loc.c)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/489>
