[GRASS-dev] [GRASS GIS] #492: grass7: XY-location makes g.region segfault
Reporter: mlennert | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 7.0.0
Component: default | Version: svn-trunk
Keywords: | Platform: Unspecified
      Cpu: Unspecified |
1) create location through wxgui wizard, option "Use arbitrary non-earth
coordinate system (XY)" or option "Use coordinate system of selected
georeferenced file" pointing at a non-georeferenced file.
2) g.region -p gives:
GRASS 7.0.svn (XY):~ > g.region -p
WARNING: <PROJ_INFO> file not found for location <XY>
WARNING: <PROJ_UNITS> file not found for location <XY>
Segmentation fault
This also leads to a crash of the GUI. I'll report this as a separate bug.
devel6-tree does not show this problem.
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/492&gt;
  Reporter: mlennert | Owner: martinl
      Type: defect | Status: assigned
Resolution: | Keywords:
  Platform: Unspecified | Cpu: Unspecified
Changes (by martinl):
  * status: new => assigned
  * owner: grass-dev@lists.osgeo.org => martinl
* cc: grass-dev@lists.osgeo.org (added)
Comment:
Hopefully fixed in r35855.
Ticket URL: <http://trac.osgeo.org/grass/ticket/492#comment:1&gt;
Comment (by mlennert):
Works now. Thanks !
Only question: I still get the warnings:
Are they really necessary ?
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/492#comment:2&gt;
Comment (by hamish):
Replying to [comment:2 mlennert]:
not for a XY location, which is unPROJected.
create a simple XY location from the text prompts and you will see that
those files are not created.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/492#comment:3&gt;
Replying to [comment:3 hamish]:
My question referred to the warnings, not the files :wink:
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/492#comment:4&gt;
Comment (by martinl):
I think these warning could be suppressed for unprojected locations.
Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/492#comment:5&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
  * status: assigned => closed
  * resolution: => fixed
Comment:
Replying to [comment:5 martinl]:
Done in r37590.
Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/492#comment:6&gt;
