GDAL
February 17, 2009, 4:40am
1
#495: v.out.ascii: warning message when layer=2
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Vector | Version: 6.4.0 RCs
Keywords: v.out.ascii, layer | Platform: Linux
Cpu: x86-32 |
when trying to do v.out.ascii for layer=2 I get tons of
WARNING: Feature has more categories. Only first category (1) is exported.
One for every single point. It's rather annoying to see so many and I'm
not really clear about what it actually means. Will only layer 1 be
exported even when I specifically asked for layer 2?
example:
#spearfish
v.in.ascii out=surv_track format=standard -n << EOF
L 3 1
608119 4915294
606085 4919979
599926 4920470
1 1
EOF
# v.to.points creates 2 layers
v.to.points in=surv_track out=surv_pts dmax=100
v.out.ascii surv_pts layer=2
[noise]
(in my real case I've added a new column to layer 2 and use the new
v.out.ascii columns= to export those values)
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/495> ;
GRASS GIS <http://grass.osgeo.org >
GDAL
February 17, 2009, 4:56am
2
#495: v.out.ascii: layer=2 column output wrong
Priority: critical | Milestone: 6.4.0
Resolution: | Keywords: v.out.ascii, layer
Platform: Linux | Cpu: x86-32
Changes (by hamish):
* priority: major => critical
* summary: v.out.ascii: warning message when layer=2 => v.out.ascii:
Comment:
Ah, I (think I) see what the warning means,
v.out.ascii tmp_point_9669 layer=2 column=width 2> /dev/null | head
608119|4915294|1|594.62231400
608079.22533499|4915385.61470284|1|594.62231400
608039.45066998|4915477.22940567|1|594.62231400
607999.67600497|4915568.84410851|1|594.62231400
607959.90133996|4915660.45881135|1|594.62231400
607920.12667495|4915752.07351418|1|594.62231400
607880.35200994|4915843.68821702|1|594.62231400
607840.57734493|4915935.30291985|1|594.62231400
607800.80267992|4916026.91762269|1|594.62231400
607761.02801492|4916118.53232553|1|594.62231400
it means that it is mixing up cats from layer=1 and layer=2.
layer=1 cat is always 1 in this map (orig cat of v.to.points input line)
and so it retrieves the layer=2 cat=1 value (594.622) for all points
instead of by layer 2 cats:
v.db.select tmp_point_9669 layer=2 | head
cat|lcat|along|width
1|1|0|594.622314
2|1|99.876312|550.689599
3|1|199.752625|460.65393
4|1|299.628937|410.969189
5|1|399.505249|454.671559
6|1|499.381561|457.451076
7|1|599.257874|472.407835
8|1|699.134186|562.410718
9|1|799.010498|597.98247
changing title of bug & increasing severity.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/495#comment:1> ;
GDAL
February 19, 2009, 10:26am
3
Reporter: hamish | Owner: martinl
Type: defect | Status: assigned
Changes (by martinl):
* status: new => assigned
* owner: grass-dev@lists.osgeo.org => martinl
* cc: grass-dev@lists.osgeo.org (added)
Comment:
Hopefully fixed in r35918 (devbr6), r35936 (trunk) and r35937 (relbr64).
Ticket URL: <http://trac.osgeo.org/grass/ticket/495#comment:2> ;
GDAL
February 22, 2009, 9:12am
4
Type: defect | Status: closed
Resolution: fixed | Keywords: v.out.ascii, layer
* status: assigned => closed
* resolution: => fixed
Comment:
seems to work now, thanks.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/495#comment:3> ;
