Hoping for feedback... r.sun still needs a fix for LatLong.
---------- Forwarded message ----------
Date: Sat, Mar 14, 2009 at 9:09 AM
Subject: Re: [GRASS-dev] [GRASS GIS] #498: r.sun2 out of sync / broken
svn history
To: Hamish
On Fri, Mar 13, 2009 at 11:40 AM, Hamish <hamish_b@yahoo.com> wrote:
MN:
I am looking in devel_branch6:
Is that the same as in the comment? I am not good in these
logical comparisons.ah,
https://trac.osgeo.org/grass/browser/grass/branches/develbranch_6/raster/r.sun/main.c#L1332
https://trac.osgeo.org/grass/browser/grass/branches/develbranch_6/raster/r.sun2/main.c#L1848oh yeah, it needs the latin==NULL && lt=NULL checks otherwise the
values set in the if(latin) part just before or lt earlier will
always be overwritten.hmmmm.. but then the longitude variable is not set.
some sort of if(longin) { ... clone of if(latin) { ... needed
at r.sun2/main.c#L1855 to set that???
I have attached a diff - please check.
I've used r.sun quite a bit, but never latin= or lat= options.
(nor really understood why you would use that)
nor me ...
also I notice la_min and la_max for lat= option are not set so stay
at init values of +-90deg. prob better to set max=min=latitude,
together with a -90<lat<90 check at its sscanf(). (and check sscanf
returns "1" answer; and pass through G_scan_northing() so it can accept DDD:MM:SS format)
Mhh, not sure how to do that, could you try?
(attachments)
rsun2.diff (1.03 KB)
