[GRASS-dev] [GRASS GIS] #501: wxgui: g.message getting squashed
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: wxGUI | Version: 6.4.0 RCs
Keywords: g.message | Platform: MSWindows XP
      Cpu: x86-32 |
trying to run v.in.gpsbabel from wxGUI.
(OSGeo4W install on windows xp)
[Run] button -> Command output:
(date)
v.in.gpsbabel format=gpx
which: gpsbabel: unknown command (ok, it isn't installed)
ERROR: http://gpsbabel.sourceforge.net
[date] Command finished (1 sec)
the full error message should be:
  if [ ! -x "`which gpsbabel`" ] ; then
     g.message -e "The gpsbabel program was not found, please install it
first.
                   http://gpsbabel.sourceforge.net"
     exit 1
fi
it seems the g.message newline is getting squashed into just a \r and the
bulk of the message is lost?
svn setting is ok:
$ svn propget svn:eol-style v.in.gpsbabel
native
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/501&gt;
  Reporter: hamish | Owner: martinl
      Type: defect | Status: assigned
Resolution: | Keywords: g.message
  Platform: MSWindows XP | Cpu: x86-32
Changes (by martinl):
  * status: new => assigned
  * owner: grass-dev@lists.osgeo.org => martinl
* cc: grass-dev@lists.osgeo.org (added)
Comment:
Fixed in r35998.
Ticket URL: <https://trac.osgeo.org/grass/ticket/501#comment:1&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: g.message
  * status: assigned => closed
  * resolution: => fixed
Ticket URL: <http://trac.osgeo.org/grass/ticket/501#comment:2&gt;
