GDAL
February 21, 2009, 2:46pm
1
#503: wx-GUI: html-manual
Reporter: hellik | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: wxGUI | Version: 6.4.0 RCs
Keywords: | Platform: Unspecified
Cpu: Unspecified |
hi,
if you go to
http://grass.osgeo.org/grass64/manuals/html64_user/wxGUI.html
and scroll down, you see that the manual is three or four times in one
html. the same is in the grass64rc3 (at least in the osgeo4w-grass64rc-2).
Ticket URL: <http://trac.osgeo.org/grass/ticket/503> ;
GRASS GIS <http://grass.osgeo.org >
GDAL
February 21, 2009, 2:54pm
2
Component: Docs | Version: 6.4.0 RCs
Resolution: | Keywords:
Platform: Unspecified | Cpu: Unspecified
Changes (by hellik):
* component: wxGUI => Docs
Ticket URL: <http://trac.osgeo.org/grass/ticket/503#comment:1> ;
GDAL
February 22, 2009, 5:52am
3
Priority: minor | Milestone: 6.4.0
Changes (by hamish):
* priority: major => minor
Comment:
same for wxGUI.Nviz.html and others in gui/wxpython/docs/.
apparently the 'make htmldir' command there just appends the man pages to
wxGUI.tmp.html instead of overwriting them so each time the dir is rebuilt
the man page grows... I notice that 'make distclean' does not remove the
*.tmp.html files in that dir.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/503#comment:2> ;
GDAL
February 22, 2009, 1:47pm
4
Type: defect | Status: closed
Resolution: fixed | Keywords:
Changes (by neteler):
* status: new => closed
* resolution: => fixed
Comment:
Fix (hack) submitted for devel_branch6 and 6.4.0svn: r36045 and
r36046. GRASS 7 doesn't have this problem.
It will show up next by Saturday in the online manual.
Closing ticket.
Ticket URL: <https://trac.osgeo.org/grass/ticket/503#comment:3> ;
GDAL
February 23, 2009, 2:41am
5
Type: defect | Status: reopened
* status: closed => reopened
* resolution: fixed =>
Comment:
reopening ticket, as the problem still happens and the fix actually does
nothing.
'make distclean' does not remove gui/wxpython/docs/*.tmp.html. i.e. it's
not about $(GISBASE)/docs/html/$$file.html, it's about the .tmp.html file
in the source dir.
run "make" in gui/wxpython/docs/ a few times and watch them grow.
Two problems to fix as I see it:
- 'make clean' does not clean up the .tmp.html files in docs/
and
- 'make htmldir' is appending to instead of replacing the .tmp.html
file.
not really sure about how to fix Makefile stuff,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/503#comment:4> ;
GDAL
February 23, 2009, 2:47am
6
Comment (by hamish):
this version of the hack better addresses the symptom, but not the cause:
Index: gui/wxpython/docs/Makefile
--- gui/wxpython/docs/Makefile (revision 36060)
+++ gui/wxpython/docs/Makefile (working copy)
@@ -10,4 +10,4 @@
include $(MODULE_TOPDIR)/include/Make/Rules.make
default:
- for file in $(FILES) ; do rm -f $(GISBASE)/docs/html/$$file.html;
$(MAKE) htmldir PGM=$$file; done
+ for file in $(FILES) ; do rm -f $$file.tmp.html; $(MAKE) htmldir
PGM=$$file; done
H
Ticket URL: <https://trac.osgeo.org/grass/ticket/503#comment:5> ;
GDAL
March 11, 2009, 5:30am
7
* status: reopened => closed
Comment:
Local tmp file removal submitted in changeset r36318 and r36319. Manual
regenerated, seems ok now:
Ticket URL: <http://trac.osgeo.org/grass/ticket/503#comment:6> ;
