GDAL
February 24, 2009, 9:44pm
1
#506: v.out.ascii segfault when exporting columns from the attribute table
Reporter: dylan | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.5.0
Component: default | Version: svn-develbranch6
Keywords: v.out.ascii | Platform: Unspecified
Cpu: Unspecified |
v.out.ascii is giving a segfault when a column is supplied to the
'columns' argument. Example with the spearfish database:
v.out.ascii in=bugsites format=point columns=str1
D4/5: eval_node node_type = 2
D4/5: right = 2
D4/5: right_dval = 1.000000
D4/5: operator = 11
D4/5: condition = 0
D2/5: load_table_head(): tab = 2,
/home/dylan/grass/spearfish60/PERMANENT/dbf//bugsites.dbf
Segmentation fault
I have tried this with several vector files using the DBF backend, all
with the same result. Using the MySQL backend v.out.ascii appears to work
fine.
Ticket URL: <http://trac.osgeo.org/grass/ticket/506> ;
GRASS GIS <http://grass.osgeo.org >
GDAL
February 24, 2009, 10:50pm
2
Resolution: | Keywords: v.out.ascii
Platform: Unspecified | Cpu: Unspecified
Comment (by hamish):
works for me.
I don't think it makes a difference, but //bugsites.dbf ?
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/506#comment:1> ;
- Reporter: dylan | Owner: grass-dev@lists.osgeo.org Type:
- Comment (by hamish):
works for me.
Hamish
Yeah that did look kind strange... is that something I can fix with
db.connect?
Dylan
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
GDAL
April 1, 2009, 10:09pm
4
Priority: minor | Milestone: 6.5.0
Resolution: | Keywords: v.out.ascii dbf_driver
Changes (by dylan):
* keywords: v.out.ascii => v.out.ascii dbf_driver
* priority: major => minor
Comment:
Updates: with a recent SVN update, I see that v.out.ascii columns=...
works as expected, except when the column name may be an SQL reserved
word.
This does not work:
v.out.ascii pits columns=Comment
This works:
v.out.ascii pits columns=Max_PDOP
I wonder if there is something that can be done about this...
Ticket URL: <http://trac.osgeo.org/grass/ticket/506#comment:2> ;
GDAL
May 2, 2013, 1:47am
5
#506: v.out.ascii reserved words problem when exporting columns from the
attribute table
Reporter: dylan | Owner: grass-dev@…
Component: Vector | Version: svn-develbranch6
Keywords: v.out.ascii, dbf_driver | Platform: Unspecified
Cpu: Unspecified |
Changes (by hamish):
* keywords: v.out.ascii dbf_driver => v.out.ascii, dbf_driver
* component: Default => Vector
Ticket URL: <https://trac.osgeo.org/grass/ticket/506#comment:3> ;
