imagery/i.cluster/main.c
raster/r.out.mpeg/main.c
raster/r.topmodel/misc.c
lib/gis/opencell.c G__open_cell_old()
all hardcode to /dev/null which doesn't exist on Windows.
perhaps
{{{ #ifdef __MINGW32__ #define NULLDEV "NUL:" #else #define NULLDEV "/dev/null" #endif
or somesuch? (no idea)
d.ask and XDRIVER do too, but they don't work on MS Windows.
i.cluster, r.topmodel, and lib/gis/opencell.c updated in r36143 - r36148.
For grass 6 I am not really sure what to do with r.mapcalc from
r.topmodel/misc.c. I can do
G_putenv("GRASS_VERBOSE", "0");
but then how to undo that as soon as r.mapcalc is done? ie so you don't
override user's verbosity setting for everything that happens afterwards
in the module. on unix you could put "GRASS_VERBOSE=0 r.mapcalc ..." on
the same line, dunno if that works for windows.
n.b. old >/dev/null didn't catch G_percent() as it is to stderr not
stdout.
Also I am not sure how to fix r.out.mpeg (sends 2> /dev/null), so that one
remains to be fixed.
as in comment:2 I'm not sure how to fix r.out.mpeg.
XDRIVER and d.ask aren't an issue for WinGrass.
I'm not sure if xganim could be made to work on WinGrass or not, but it's
better replaced by the wxGUI animator version. (?)
So I'd be happy to close the bug as long as r.out.mpeg could get fixed.
Replying to [comment:4 hamish]:
G_system("ppmtompeg 2>" G_DEV_NULL);
A more significant issue is gee_wildfiles(), which does:
sprintf(cmd, "cd %s; \\ls %s >> %s 2> /dev/null",
path, wildarg, tfile);
If you want a complete replacement, the 7.0 version of xganim uses
G_spawn_ex() and g.mlist.
it's better replaced by the wxGUI animator version. (?)
The 6.x xganim requires Motif and an X server, which is probably more
trouble than it's worth. Also, on Windows and MacOSX you would need to
either use Lesstif (which is still "beta" quality and barely maintained)
or buy a commercial version of Motif; the OpenMotif licence is limited to
open-source platforms.
Replying to [comment:5 glynn]:
Just for the record, `xganim` was removed from GRASS 7 in favor of
`g.gui.animation`.
For trunk, both `egrep -Irn "NULLDEV"` and `egrep -Irn "/dev/null"` return
nothing for `raster/r.out.mpeg`.
