[GRASS-dev] [GRASS GIS] #517: v.net.iso / v.net.alloc: keep original cat values or change output to field in attribute table instead of new map
  Reporter: effilc36 | Owner: grass-dev@…
  Priority: minor | Milestone: 7.4.0
Component: Vector | Version: svn-trunk
Resolution: | Keywords: v.net.iso
       CPU: All | Platform: All
Comment (by mlennert):
Replying to [comment:11 mmetz]:
> Done in r71193 for v.net.iso (new flag -u). The newly created attribute
table has the fields cat (category value), ocat (original category value),
center (category value of nearest center), isonr (iso band number), isolbl
(iso band label). A side effect is that a line is now correctly split if
it is assigned to two different centers.
Works great, thanks ! And the output is very useful, and probably more
intuitive for many.
> Done in r71194 for v.net.alloc (new flag -u). The newly created
attribute table has the fields cat (category value), ocat (original
category value), center (category value of nearest center).
This one segfaults for me when doing the following:
v.net streets_wake points=schools_wake op=connect out=network thresh=99999
v.net.alloc -u network ccats=1-5 out=alloc
valgrind reports the issue to be on line 344 of main.c:
Invalid read of size 4
==3597== at 0x10B588: main (main.c:344)
==3597== Address 0x10 is not stack'd, malloc'd or (recently) free'd
Ticket URL: <https://trac.osgeo.org/grass/ticket/517#comment:12&gt;
