#517: v.net.iso / v.net.alloc: keep original cat values or change output to field
in attribute table instead of new map
Reporter: effilc36 | Owner: grass-dev@…
Priority: minor | Milestone: 7.4.0
Component: Vector | Version: svn-trunk
Resolution: | Keywords: v.net.iso
CPU: All | Platform: All
Comment (by mmetz):
Replying to [comment:15 mlennert]:
> Is it better to have everything in a module and create wrapper modules,
or would it be more interesting to put the common part of the code into a
library ?
I would prefer to make the costs option of v.net.iso optional and make
v.net.alloc a wrapper for v.net.iso.
If other modules need that functionality as well, the code part that
assigns centers to nodes could be put into the neta library. The existing
functions NetA_distance_[from|to]_points() are similar, but return the
paths to nearest centers instead of the nearest centers themselves.
Ticket URL: <https://trac.osgeo.org/grass/ticket/517#comment:16>
