GDAL
March 7, 2009, 4:09pm
1
#523: wxGUI: querying a vector map in edit mode does nothing
Reporter: msieczka | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Keywords: | Platform: All
Cpu: All |
1. Load a vector map.
2. Zoom to it.
3. Query the map in "edit mode" - nothing happens. In vdigit query and
editing works.
SVN r36231.
Ticket URL: <http://trac.osgeo.org/grass/ticket/523> ;
GRASS GIS <http://grass.osgeo.org >
GDAL
March 13, 2009, 4:06pm
2
Resolution: | Keywords:
Platform: All | Cpu: All
Comment (by martinl):
Seems to work for me. Can you post NC-based example?
Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/523#comment:1> ;
GDAL
March 13, 2009, 5:00pm
3
Comment (by hellik):
Replying to [comment:1 martinl]:
> Martin
grass64rc3-3 (osgeo4w) - win vista
data nc-spm
g.copy vect=lakes@PERMANENT,test
loading test in wx-gis-map-display
querying test map in edit mode => window for update attributes pop up
but submit a change for example in the field "FTYPE" (character) from
RESERVOIR to DAM
then following error message:
File "C:\OSGeo4W\apps\grass\grass-6.4.0RC3\etc\wxpython\gu
i_modules\dbm.py", line 3101, in OnSubmit
"input=%s" % sqlFile.name])
i_modules\gcmd.py", line 355, in __init__
_("Error: ") + self.GetError()))
gui_modules.gcmd
CmdError
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/523#comment:2> ;
GDAL
March 14, 2009, 12:16pm
4
Comment (by msieczka):
Seems translation-related issue. I can reproduce it for any vector map,
but *only in Polish translation*. After "export LC_ALL=C" works fine.
Spearfish example:
1. start GRASS
2. add "streams" vector map
3. select it, "Zoom to selected map"
3. in "Map display" window: "Query raster/vector maps" > "Query vector map
(edit mode)"
4. left click a line on the map display - nothing happens
Querying vectors works fine though in "display mode" even in Polish
translation.
Reminds me of http://trac.osgeo.org/grass/ticket/427#comment:5 . Are there
more such issues possible?
Ticket URL: <http://trac.osgeo.org/grass/ticket/523#comment:3> ;
GDAL
March 14, 2009, 12:25pm
5
Comment (by neteler):
I found this which looks suspicious:
#: ../gui/wxpython/gui_modules/mapdisp.py:163
msgid "Render"
-msgstr "_Renderuj"
+msgstr "Renderuj"
Could you fix that locally and regenerate the mo file?
Ticket URL: <http://trac.osgeo.org/grass/ticket/523#comment:4> ;
GDAL
March 14, 2009, 2:02pm
6
Replying to [comment:2 hellik]:
> gui_modules.gcmd
> CmdError
Fixed in r36377.
Ticket URL: <http://trac.osgeo.org/grass/ticket/523#comment:5> ;
GDAL
March 14, 2009, 2:30pm
7
Reporter: msieczka | Owner: martinl
Type: defect | Status: assigned
Changes (by martinl):
* status: new => assigned
* owner: grass-dev@lists.osgeo.org => martinl
* cc: grass-dev@lists.osgeo.org (added)
Comment:
Replying to [comment:3 msieczka]:
yes, it's problem with v.what. Temporally fixed in r36378. v.what should
have script-style output which is not based on used locales.
Ticket URL: <http://trac.osgeo.org/grass/ticket/523#comment:6> ;
GDAL
March 14, 2009, 4:58pm
8
In r36380 the problem is still not fixed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/523#comment:7> ;
GDAL
March 14, 2009, 6:44pm
9
Replying to [comment:7 msieczka]:
export LC_ALL=pl_PL.utf8
grass65
* add vector, zoom, query in edit mode
works. M.
Ticket URL: <http://trac.osgeo.org/grass/ticket/523#comment:8> ;
GDAL
March 14, 2009, 9:31pm
10
Replying to [comment:8 martinl]:
> grass65
> works
True :). However, without explicit "export LC_ALL=pl_PL.utf8" it still
doesn't.
My default locale settings are:
$ locale
LANG=pl_PL.UTF-8
LC_CTYPE="pl_PL.UTF-8"
LC_NUMERIC="pl_PL.UTF-8"
LC_TIME="pl_PL.UTF-8"
LC_COLLATE="pl_PL.UTF-8"
LC_MONETARY="pl_PL.UTF-8"
LC_MESSAGES="pl_PL.UTF-8"
LC_PAPER="pl_PL.UTF-8"
LC_NAME="pl_PL.UTF-8"
LC_ADDRESS="pl_PL.UTF-8"
LC_TELEPHONE="pl_PL.UTF-8"
LC_MEASUREMENT="pl_PL.UTF-8"
LC_IDENTIFICATION="pl_PL.UTF-8"
LC_ALL=
Ticket URL: <http://trac.osgeo.org/grass/ticket/523#comment:9> ;
GDAL
March 14, 2009, 11:46pm
11
Comment (by glynn):
Replying to [comment:6 martinl]:
map, but *only in Polish translation*. After "export LC_ALL=C" works fine.
Not really; see comment:9. It also needs to set LC_MESSAGES.
BTW, the GUI should leave os.environ alone; pass env=... to Popen() to
control the environment for child processes.
> v.what should have script-style output which is not based on used
locales.
Agreed. Setting LC_MESSAGES is overkill (LC_ALL more so), as it will also
affect error messages meant for the user.
Ticket URL: <http://trac.osgeo.org/grass/ticket/523#comment:10> ;
GDAL
September 19, 2009, 4:43am
12
Component: Translations | Version: svn-develbranch6
Changes (by cmbarton):
* component: wxGUI => Translations
Comment:
It's not clear whether this is fixed or not. But in either case, it is not
a GUI problem but a problem with translations and and how they interact
with grass modules like v.what. I'm changing the component to
"translations". Maybe someone with another localization can see if it is
fixed or not.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/523#comment:11> ;
GDAL
October 7, 2012, 9:52am
13
Cpu: All |
Comment(by martinl):
Asking the reporter, is this ticket still relevant to the recent version -
6.4.3svn?
Ticket URL: <http://trac.osgeo.org/grass/ticket/523#comment:12> ;
GDAL
July 24, 2013, 12:40pm
14
Type: defect | Status: closed
Resolution: worksforme | Keywords:
Changes (by mlennert):
* status: assigned => closed
* resolution: => worksforme
Comment:
Replying to [comment:12 martinl]:
- 6.4.3svn?
As there has been no response for 10 months, I'm closing this ticket.
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/523#comment:13> ;
GDAL
July 24, 2013, 12:57pm
15
Type: defect | Status: reopened
Changes (by hamish):
* status: closed => reopened
* resolution: worksforme =>
Comment:
Please confirm bugs as fixed before closing them.
thanks, Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/523#comment:14> ;
GDAL
July 24, 2013, 3:51pm
16
Comment(by mlennert):
This was for 6.4.0 where wxgui was still an infant. Much of the layer
interrogation features has significantly changed since then.
I cannot reproduce these issues on Debian GNU/Linux (in GRASS7 there is no
interactive editing of attributes outside the digitiser, AFAIK).
Can someone test on Windows ?
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/523#comment:15> ;
