[GRASS-dev] [GRASS GIS] #53: init.sh: cleanup session $tmp on exit and require -c to create mapset from the command line
the command line
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
     Type: task | Status: new
Priority: minor | Milestone: 6.4.0
Component: default | Version: unspecified
Keywords: |
the attached patch does two things:
  * If you exit GRASS in an abnormal way (even from the startup GUI "Exit"
button) it left behind old dirs in /tmp. This fixes that.
  * In 6.3 if you start grass from the command line with the path to the
mapset as a parameter it will create a new mapset for you if it doesn't
exist (after checking that the location is valid). This patch adds a -c
flag to the grass63 startup script for that case, to avoid the silent
success of 'grass63 /path/to/typo' bugs.
Users who currently rely on this feature in batch grass scripts can set
  export CREATE_NEW=1
before starting their script to mimic the old way.
Posting this patch to the tracker instead of applying it directly in SVN
to get input from anyone who uses this style of automatic mapset creation
in scripts.
this should not have any bearing on trac bug #7 (which I still hope to
spend some time on at some point).
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/53&gt;
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
the command line
      Type: task | Status: closed
Resolution: fixed | Keywords:
Changes (by hamish):
  * status: new => closed
  * resolution: => fixed
Comment:
applied in svn/trunk.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/53#comment:1&gt;
