[GRASS-dev] [GRASS GIS] #534: g.gui doesn't work in ms-windows
Reporter: cnielsen | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: unspecified
Keywords: | Platform: MSWindows XP
      Cpu: Unspecified |
From a self-compiled version (mingw/msys), or osgeo4w version, g.gui fails
to restart the gui on windows. For the osgeo4w version I created a grass64
file and started from within an msys shell. No error messages appear in
either case.
Fails to restart either the tcltk or wxpython gui
GRASS 6.4.0RC3 (Latlong):/d > g.gui wxpython
Ticket URL: <http://trac.osgeo.org/grass/ticket/534&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
  Platform: MSWindows XP | Cpu: Unspecified
Changes (by cnielsen):
  * status: new => closed
  * resolution: => fixed
Comment:
seems to be fixed
Ticket URL: <http://trac.osgeo.org/grass/ticket/534#comment:1&gt;
      Type: defect | Status: reopened
Resolution: | Keywords:
Changes (by neteler):
  * status: closed => reopened
  * resolution: fixed =>
Ticket URL: <http://trac.osgeo.org/grass/ticket/534#comment:2&gt;
Component: default | Version: svn-releasebranch64
  * version: unspecified => svn-releasebranch64
Comment:
The problem persists on WindowsXP, Japanese version. See attachement.
Ticket URL: <http://trac.osgeo.org/grass/ticket/534#comment:3&gt;
Component: wxGUI | Version: svn-releasebranch64
  * component: default => wxGUI
Comment:
I tried with "tcltk" as parameter and it works. So the problem is "only"
to launch "wxpython", in general g.gui.exe seems to be ok.
Ticket URL: <http://trac.osgeo.org/grass/ticket/534#comment:4&gt;
Comment (by glynn):
Replying to [comment:4 neteler]:
So the problem is with wxGUI, not g.gui? Does:
$GRASS_PYTHON $GISBASE/etc/wxpython/wxgui.py &
work?
Ticket URL: <http://trac.osgeo.org/grass/ticket/534#comment:5&gt;
Comment (by glynn):
Replying to [comment:5 glynn]:
> Does:
> work?
Duh; this is Windows; that should be:
"%GRASS_PYTHON%" "%WINGISBASE%\etc\wxpython\wxgui.py"
Ticket URL: <http://trac.osgeo.org/grass/ticket/534#comment:6&gt;
Comment (by neteler):
Tested: the (simple) problem is that "%GRASS_PYTHON%" is not defined at
all. When defining it manually (set GRASS_PYTHON=python), also g.gui
works.
I see that the variable is defined in lib/init/init.sh but not in any .bat
file.
Ticket URL: <http://trac.osgeo.org/grass/ticket/534#comment:7&gt;
Changes (by heshikik):
* cc: heshikik (added)
Ticket URL: <http://trac.osgeo.org/grass/ticket/534#comment:8&gt;
Comment (by hamish):
Replying to [comment:7 neteler]:
> in any .bat file.
only by mswindows/osgeo4w/ini.bat.tmpl?
osgeo4w/ini.bat.tmpl:5:set GRASS_PYTHON=%OSGEO4W_ROOT%\bin\python.exe
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/534#comment:9&gt;
testing on wingrass prev binary r40019-
from the "GRASS 6.4.SVN with MSYS" terminal prompt $GRASS_PYTHON is set
(presumably by init.sh) and "g.gui wxpython" works.
from the "GRASS Command Line" menu item DOS-box %GRASS_PYTHON% is not set
and "g.gui wxpython" fails unless I set it. It is best to fix init.bat of
course, but perhaps we could also add a check to see if the getenv() in
g.gui.c is empty, and if it is default to "python"?
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/534#comment:10&gt;
Replying to [comment:10 hamish]:
set and "g.gui wxpython" fails unless I set it. It is best to fix init.bat
of course, but perhaps we could also add a check to see if the getenv() in
A default sounds good to me (just to "python") - if python is absent it
would fail in any case.
Ticket URL: <http://trac.osgeo.org/grass/ticket/534#comment:11&gt;
This trac comment apparently didn't make it to the list:
http://trac.osgeo.org/grass/ticket/534#comment:12
patch attached to this ticket vs. trunk to solve this in three different ways/places.
I'm a bit murky on the G_store() usage, so review before committing.
Hamish
setting GRASS_PYTHON=python at the DOS prompt works.
I've committed to all branches the init.sh and grass.bat fixes from the
patch. see svn r40435-7.
Putting a fail-safe in g.gui.c still needs to be decided but is not a
blocker for release.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/534#comment:13&gt;
Resolution: | Keywords: wingrass
Changes (by hamish):
  * keywords: => wingrass
Ticket URL: <https://trac.osgeo.org/grass/ticket/534#comment:14&gt;
I'm a bit murky on the G_store() usage, so review.
svn diff trunk/general/g.gui/main.c
Index: main.c
--- main.c (revision 40408)
+++ main.c (working copy)
@@ -27,7 +27,7 @@
      struct Option *type, *rc_file;
      struct Flag *update, *nolaunch;
      struct GModule *module;
- const char *gui_type_env;
+ const char *gui_type_env, *python_cmd;
      char progname[GPATH_MAX];
      G_gisinit(argv[0]);
@@ -103,14 +103,19 @@
      G_debug(1, "Attempting to start '%s' GUI ...", type->answer);
+ python_cmd = getenv("GRASS_PYTHON");
+ if(!python_cmd)
+ python_cmd = G_store("python");
      if (strcmp(type->answer, "wxpython") == 0) {
         sprintf(progname, "%s/etc/wxpython/wxgui.py", G_gisbase());
         if (rc_file->answer) {
- G_spawn_ex(getenv("GRASS_PYTHON"), progname, progname,
+ G_spawn_ex(python_cmd, progname, progname,
                     "--workspace", rc_file->answer, SF_BACKGROUND, NULL);
         else {
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/534#comment:15&gt;
Comment (by glynn):
Replying to [comment:13 hamish]:
It would also need to go into lib/gis/parser.c, g.mapsets/main.c,
scripts/wxpyimgview/wxpyimgview.py, v.krige.py and d.rast.edit.py (when
they eventually get fixed), and anything else which uses $GRASS_PYTHON.
IOW, it '''needs''' to be set in the startup scripts. Adding workarounds
for specific cases is fixing the symptoms rather than the bug.
Ticket URL: <https://trac.osgeo.org/grass/ticket/534#comment:16&gt;
Resolution: fixed | Keywords: wingrass
  * status: reopened => closed
Comment:
ok, primary subject of bug is fixed on all platforms; adding multiple
layers of redundancy to deal with missing GRASS_PYTHON and GRASS_WISH
enviro variables will be a wontfix. we can reconsider that later if it
ever becomes a real problem.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/534#comment:17&gt;
