GDAL
21
#536: memory corruption
Reporter: martinl | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: reopened
Priority: blocker | Milestone: 7.0.0
Component: Vector | Version: svn-trunk
Resolution: | Keywords:
Platform: Linux | Cpu: x86-32
Comment (by martinl):
Replying to [comment:19 mmetz]:
> Doesn't make any sense to me why ifield[0] should get a random value.
Maybe just use the working solution?
yes, there is something strange with GRASS7 compilation on my computer
(note that I have no problems with GRASS6). E.g. debugging v.select
(gdb) b main.c:176 [for (iopt = 0; iopt < 2; iopt++) {]
(gdb) b main.c:184 [Vect_open_old(&(In[iopt]), parm.input[iopt]->answer,
(gdb) b main.c:188 [IFi = Vect_get_field(&(In[0]), ifield[0]);]
(gdb) r
(gdb) p ifield[0]
$4 = -163754450
(gdb) c
(gdb) p ifield[0]
$5 = 1
(gdb) c
(gdb) c
(gdb) p ifield[0]
$10 = 142560728
Nice mystery
M.
Ticket URL: <http://trac.osgeo.org/grass/ticket/536#comment:20>
GDAL
22
#536: memory corruption in vector modules
Changes (by hamish):
* summary: memory corruption => memory corruption in vector modules
Ticket URL: <http://trac.osgeo.org/grass/ticket/536#comment:21>
GDAL
23
Comment (by mmetz):
Martin, are you still observing memory corruption in vector modules in
grass7?
If yes, is your system 32 bit or 64 bit? If 32 bit, does memory corruption
disappear when configuring without --enable-largefile?
This memory corruption may have something to do with the new LFS support
for vector libs, then I could have an idea how to fix it.
Ticket URL: <https://trac.osgeo.org/grass/ticket/536#comment:22>
GDAL
24
Comment (by mmetz):
Hopefully fixed in r37861, please test.
Ticket URL: <https://trac.osgeo.org/grass/ticket/536#comment:23>
GDAL
25
Reporter: martinl | Owner: grass-dev@…
Type: defect | Status: closed
Resolution: fixed | Keywords:
Changes (by mmetz):
* status: reopened => closed
* resolution: => fixed
Comment:
No complaints in the last 3 years, closing as fixed.
Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/536#comment:24>
