#539: Error on "Display Map" in wxpython
Reporter: cnielsen | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Keywords: | Platform: MSWindows Vista
Cpu: Unspecified |
When I click display map in wxpython, nothing happens. The following error
appears in command output:
File "c:\Programs\GIS\osgeo4w\apps\grass\grass-6.5.svn\etc
\wxpython\gui_modules\mapdisp.py", line 541, in OnDraw
self.MapWindow.UpdateMap(render=False)
\wxpython\gui_modules\mapdisp_window.py", line 661, in
UpdateMap
self.Draw(self.pdc, self.img, drawid=id)
\wxpython\gui_modules\mapdisp_window.py", line 289, in Draw
pdc.DrawBitmap(bitmap, wx.Point(coords[0], coords[1]), True)
# draw the composite map
File "C:\Programs\GIS\OSGeo4W\apps\Python25\lib\site-
packages\wx-2.8-msw-unicode\wx\_gdi.py", line 7526, in
DrawBitmap
return _gdi_.PseudoDC_DrawBitmap(*args, **kwargs)
TypeError
in method 'PseudoDC_DrawBitmap', expected argument 3 of type
'int'
This is a build of develbranch_6 within the osgeo4w tree on vista.
Priority: major | Milestone: 6.5.0
Resolution: | Keywords:
Platform: MSWindows Vista | Cpu: Unspecified
Comment (by cnielsen):
Still no resolution to this bug, perhaps it relates to the change from
mapdisp.py
pdc.DrawBitmap(bitmap, coords[0], coords[1], True) # draw the composite
map
To mapdisp_window.py:
pdc.DrawBitmap(bitmap, wx.Point(coords[0], coords[1]), True) # draw the
composite map
The error says "expected argument 3 of type 'int'" and it seems that it is
still looking for "coords[1]" when in the latter case it is instead
getting "true" since "coords[1]" has been put within wx.Point as part of
arg 2.
Trying to trace this back I noticed that the
grass-6.5.svn/etc/wxpython/vdigit folder is empty. Apparently vdigit isn't
compiling at all. Ideas?
On second thought, you shouldn't need (and didn't need before) support for
vdigit just to display a map. It seems that it got incorporated as a
requirement rather than an option somewhere along the line.
Changes (by cnielsen):
* cc: jef@norbit.de (added)
Comment:
Replying to [comment:7 jef]:
> see also http://trac.osgeo.org/osgeo4w/ticket/37#comment:13 ff
That ticket includes information about vdigit and nviz but they're still
not functioning in the osgeo4w builds right?
Do I need to run {{{package.cmd}}} to make a functioning GUI? If so I'm
missing {{{h:\windows\wxPython-src-2.8.9.1}}} and my attempts to get it
from the wxpython/wxwidgets svn were unsuccessful...
I'm still missing something, but I see that you didn't need --python or
--wxwidgets in your osgeo4w builds.
Comment (by jef):
Replying to [comment:8 cnielsen]:
Yes.
So I resorted to building wxPython with VC++ 2008 Express Edition -
leading to the described problems. Later I tried with VS2003, which
didn't significantly changed anything.
Exactly. GRASS is not aware of distutils, which AFAIK should be used to
build python extensions.
