[GRASS-dev] [GRASS GIS] #540: wxGUI - Map Display only in the task bar
Reporter: hellik | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 6.5.0
Component: wxGUI | Version: svn-develbranch6
Keywords: wx-GUI, task bar | Platform: MSWindows Vista
      Cpu: Unspecified |
GRASS-devel6, build from source rev. 36355
the starting window is ok, i can choose the nc-dataset
the Layer Manager appears normally, but the Map display is only in the
task bar
and the following erros message:
   File "c:\OSGeo4W\apps\grass\grass-6.5.svn\etc\wxpython\gui
_modules\mapdisp_window.py", line 536, in OnIdle
self.UpdateMap(render=True)
_modules\mapdisp_window.py", line 635, in UpdateMap
windres=windres)
_modules\render.py", line 915, in Render
os.environ["GRASS_REGION"] = self.SetRegion(windres)
_modules\render.py", line 717, in SetRegion
region = self.AdjustRegion()
_modules\render.py", line 504, in AdjustRegion
self.region["nsres"] = mapheight / self.height
ZeroDivisionError
float division
if i do the same action in osgeo4w-GRASS64-rc, everything is ok.
best regards
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/540&gt;
Resolution: | Keywords: wx-GUI, task bar
  Platform: MSWindows Vista | Cpu: Unspecified
Comment (by hellik):
sorry, i saw it to late:
maybe related to
http://trac.osgeo.org/grass/ticket/539
Ticket URL: <http://trac.osgeo.org/grass/ticket/540#comment:1&gt;
Replying to [ticket:540 hellik]:
task bar
> windres=windres)
> ZeroDivisionError
> float division
> best regards
> Helmut
also in the actual grass6.4svn of Osgeo4W in Win Vista
Best regards
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/540#comment:2&gt;
grass6_devel self compiled in the osgeo4w-stack on WinVista
rev39094
no such behaviour in rev39094
best regards
helli
Ticket URL: <http://trac.osgeo.org/grass/ticket/540#comment:3&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: wx-GUI, task bar
Changes (by cmbarton):
* cc: cnielsen (added)
  * status: new => closed
  * resolution: => fixed
Comment:
This is no longer happening on Colin Nielsen's WinGRASS binaries in either
XP or Vista in 6.4RC5 recently built. Has anyone else reported it? I'm
closing, but it can be reopened if it turns out that it is showing up
under some particular circumstances.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/540#comment:4&gt;
