GDAL
April 3, 2009, 6:53am
1
#545: r.cost warning on negative values
Reporter: pcav | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: 6.3.0
Keywords: | Platform: Unspecified
Cpu: Unspecified |
In case ov even a few negative values, r.cost fails badly (running
forever).
If the cost map contains any negative values, it should either
generate a fatal error, or treat such cells as nulls (exclude them or
use the null_cost= value) and generate a warning.
Thanks Glynn for the hint.
Ticket URL: <https://trac.osgeo.org/grass/ticket/545> ;
GRASS GIS <http://grass.osgeo.org >
GDAL
April 3, 2009, 7:40am
2
Resolution: | Keywords:
Platform: Unspecified | Cpu: Unspecified
Comment (by neteler):
Perhaps add a test in the NULL testing section
source:grass/trunk/raster/r.cost/main.c@35369#L397
Ticket URL: <https://trac.osgeo.org/grass/ticket/545#comment:1> ;
GDAL
April 9, 2009, 12:53pm
3
Glynn: http://lists.osgeo.org/pipermail/grass-user/2009-April/049731.html
Patch proposal attached.
Ticket URL: <http://trac.osgeo.org/grass/ticket/545#comment:2> ;
GDAL
July 11, 2009, 9:17am
4
Component: Raster | Version: 6.3.0
Resolution: | Keywords: r.cost
Changes (by martinl):
* keywords: => r.cost
* component: default => Raster
Ticket URL: <http://trac.osgeo.org/grass/ticket/545#comment:3> ;
GDAL
August 19, 2012, 10:58pm
5
Reporter: pcav | Owner: grass-dev@…
Priority: major | Milestone: 6.4.3
Keywords: r.cost | Platform: Unspecified
Cpu: Unspecified |
Changes (by neteler):
* milestone: 6.4.0 => 6.4.3
Comment:
Applied to GRASS 6.5.svn in r52740.
Needs to be backported to 6.4.
Ticket URL: <http://trac.osgeo.org/grass/ticket/545#comment:4> ;
GDAL
August 20, 2012, 7:58am
6
Type: defect | Status: closed
Resolution: fixed | Keywords: r.cost
Changes (by mmetz):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [comment:4 neteler]:
Done in r52748, also for trunk in r52746.
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/545#comment:5> ;
