[GRASS-dev] [GRASS GIS] #548: grass7: v.reclass segfaults on string column
Reporter: mlennert | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 7.0.0
Component: Vector | Version: svn-trunk
Keywords: | Platform: Unspecified
      Cpu: Unspecified |
With today's devel7 trunk, v.reclass segfaults when trying to use a string
column as reclass criterium. Using nc_spm_06 demo data:
v.reclass in=boundary_county out=test_recl column=DOT_GROUP_
segfaults, whereas
v.reclass in=boundary_county out=test_recl2 column=DOT_COUNTY
works as expected (DOT_COUNTY is integer).
In grass65svn, both commands work as expected.
This also obviously makes v.dissolve fail on such columns.
Backtrace attached.
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/548&gt;
Resolution: | Keywords:
  Platform: Unspecified | Cpu: Unspecified
Comment (by neteler):
For me both commands work (I did: svn up ; make distclean).
Ticket URL: <http://trac.osgeo.org/grass/ticket/548#comment:1&gt;
Comment (by mlennert):
Replying to [comment:1 neteler]:
Using grass7 and the above example from the nc_spm_06 data set ?
Same here...
I'll have to see what's going on locally, then.
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/548#comment:2&gt;
Resolution: | Keywords: v.reclass
Changes (by martinl):
* cc: martinl` (added)
  * keywords: => v.reclass
  * priority: major => normal
Comment:
Replying to [ticket:548 mlennert]:
string column as reclass criterium. Using nc_spm_06 demo data:
> segfaults, whereas
Works fine with DBF driver. When reclassing data using string column you
get with SQLite driver know error.
DBMI-SQLite driver error:
Cannot step:
SQL logic error or missing database
No segfault here.
Ticket URL: <http://trac.osgeo.org/grass/ticket/548#comment:3&gt;
For me even that works:
GRASS 7.0.svn (nc_spm_08):~/grassdata/nc_spm_08/neteler > v.reclass
  100%
Building topology for vector map <test_recl>...
Registering primitives...
2836 primitives registered
268782 vertices registered
Building areas...
  100%
926 areas built
130 isles built
Attaching islands...
  100%
Attaching centroids...
  100%
Number of nodes: 2040
Number of primitives: 2836
Number of points: 0
Number of lines: 0
Number of boundaries: 1910
Number of centroids: 926
Number of areas: 926
Number of isles: 130
v.reclass complete. 926 features reclassed.
GRASS 7.0.svn (nc_spm_08):~/grassdata/nc_spm_08/neteler > db.connect -p
driver:sqlite
database:$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db
schema:
group:
Ticket URL: <http://trac.osgeo.org/grass/ticket/548#comment:4&gt;
Comment (by martinl):
Replying to [comment:4 neteler]:
> driver:sqlite
> schema:
> group:
v.db.connect boundary_county -g
I suppose DBF driver. Then it works... The key is the driver used for
input vector map.
Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/548#comment:5&gt;
input vector map.
Good point, indeed I was reading it with @neteler from a DBF mapset
(my bad, sorry). Copying it over into the SQLite DB fails however:
1. I made a copy of "boundary_county" in my own mapset "neteler" (DBF)
   from PERMANENT
2. Then I switched into the sqlite mapset and run:
g.copy vect=boundary_county@neteler,boundary_county
Program received signal SIGSEGV, Segmentation fault.
#gdb:
0x00007f979f9a3d69 in rtree_load_from_sidx (fp=0x7fffa8a8c5c8,
rootpos=179105, t=0xe67010, off_t_size=4)
    at spindex_rw.c:735
735 newnode->branch[j].child = NULL;
(gdb) bt
#0 0x00007f979f9a3d69 in rtree_load_from_sidx (fp=0x7fffa8a8c5c8,
    at spindex_rw.c:735
#1 0x00007f979f9a4228 in dig_Rd_spidx (fp=0x7fffa8a8c5c8,
Plus=0x7fffa8a8c3b0) at spindex_rw.c:843
#2 0x00007f97a065dfff in Vect_open_sidx (Map=0x7fffa8a8c3a0, mode=1)
at open.c:891
#3 0x00007f97a065ca70 in Vect__open_old (Map=0x7fffa8a8c3a0,
name=0xe62bc0 "boundary_county",
    mapset=0xe5e650 "sqlite", update=1, head_only=1) at open.c:262
#4 0x00007f97a065d295 in Vect_open_update_head (Map=0x7fffa8a8c3a0,
    mapset=0xe5e650 "sqlite") at open.c:522
#5 0x00007f97a065760a in Vect_copy (in=0x7fffa8a891d0
"boundary_county", mapset=0xe635f0 "neteler",
    out=0xe62bc0 "boundary_county") at map.c:237
#6 0x0000000000401b5e in do_copy (n=2, old=0xe62ae0
"boundary_county@neteler", mapset=0xe62f20 "neteler",
    new=0xe62bc0 "boundary_county") at do_copy.c:27
#7 0x00000000004019a5 in main (argc=3, argv=0x7fffa8a8f428) at main.c:93
It is unrelated hence I don't clutter the trac ticket.
Once this works, I continue with the ticket.
I will look into it, it's the new spatial index.
Markus M
input vector map.
   from PERMANENT
#gdb:
    at spindex_rw.c:735
(gdb) bt
    at spindex_rw.c:735
at open.c:891
grass-dev mailing list
#gdb:
    at spindex_rw.c:735
Fixed in r38615.
Markus M
After the fix in the spatial index I can reproduce the problem with
SQLite:
g.gisenv set=DEBUG=3
v.reclass in=boundary_county out=test_recl column=DOT_GROUP_ --o
db_driver_open_database()
D3/3: name = '/home/neteler/grassdata/nc_spm_08/sqlite/sqlite.db'
D2/3: name2 = '/home/neteler/grassdata/nc_spm_08/sqlite/sqlite.db'
D3/3: SQL: SELECT cat, DOT_GROUP_ FROM boundary_county ORDER BY
DOT_GROUP_
D3/3: Escaped SQL: SELECT cat, DOT_GROUP_ FROM boundary_county ORDER BY
DOT_GROUP_
D3/3: describe_table()
D3/3: ncols = 2
D3/3: sqltype = 3
D3/3: litetype = 1
D3/3: sqltype = 1
D3/3: litetype = 3
D3/3: nkcols = 2
D3/3: sqltype = 3
D3/3: litetype = 1
D2/3: col: cat, nkcols 0, litetype : 1, sqltype 3
D3/3: sqltype = 1
D3/3: litetype = 3
D2/3: col: DOT_GROUP_, nkcols 1, litetype : 3, sqltype 1
D3/3: 926 rows selected
D3/3: key type = 15
D3/3: execute: create table test_recl (cat integer, DOT_GROUP_
varchar(20))
D3/3: db__create_index()
D3/3: SQL: create unique index test_recl_cat on test_recl ( cat )
D3/3: fetch row = -1
Cannot step:
ERROR: Unable to fetch data from table <boundary_county>
No mention on http://www.sqlite.org/omitted.html, so I don't know why this
statement is rejected.
Ticket URL: <http://trac.osgeo.org/grass/ticket/548#comment:6&gt;
#548: grass7 - v.reclass with sqlite driver: "Cannot step: SQL logic error or
missing database"
Component: Database | Version: svn-trunk
Resolution: | Keywords: v.reclass sqlite
Changes (by mlennert):
  * keywords: v.reclass => v.reclass sqlite
  * component: Vector => Database
  * summary: grass7: v.reclass segfaults on string column => grass7 -
              logic error or missing database"
Comment:
Replying to [comment:6 neteler]:
SQLite:
I confirm: no more segfault, don't where that came from, but same error as
Markus and Martin. Changing title of bug
Ticket URL: <http://trac.osgeo.org/grass/ticket/548#comment:7&gt;
missing database"
Comment (by wilsonadam):
I can confirm this in GRASS 6.4.0RC5 (2009) with a string field (using my
data, but it does the same thing).
v.reclass in=pgrid out=pgrid2 type=centroid column=gridID
Cannot step:
ERROR: Unable to fetch data from table <pgrid>
Ticket URL: <http://trac.osgeo.org/grass/ticket/548#comment:8&gt;
missing database"
Reporter: mlennert | Owner: grass-dev@…
Keywords: v.reclass sqlite | Platform: Unspecified
      Cpu: Unspecified |
Changes (by neteler):
* cc: martinl` (removed)
Comment:
Still failing in current GRASS 7 SVN:
GRASS 7.0.svn (nc_spm_08@grass70):~ > v.reclass in=myboundary_county
Cannot step:
ERROR: Unable to fetch data from table <myboundary_county>
GRASS 7.0.svn (nc_spm_08@grass70):~ > v.db.connect -p myboundary_county
Vector map <myboundary_county> is connected by:
layer <1/boundary_county> table <myboundary_county> in database
</home/neteler/grassdata/nc_spm_08/grass70/sqlite.db> through driver
<sqlite> with key <cat>
It likely affects #1418 (v.dissolve failure) which suppresses error
messages from v.reclass.
Ticket URL: <http://trac.osgeo.org/grass/ticket/548#comment:9&gt;
missing database"
      Cpu: Unspecified |
Comment(by mmetz):
Replying to [comment:9 neteler]:
and the two other branches.
Debugging a bit, the problem of v.reclass with the sqlite driver seems to
be that the same database is opened twice (once by each driver instance),
which causes database locking, therefore it is not possible to use one
driver instance to fetch records from one table and use another driver
instance to insert records into another table, all in the same sqlite
database.
BTW, there is a test in lib/db if a database is already opened when
opening a database, this test is called quite often but it never
complains.
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/548#comment:10&gt;
missing database"
      Cpu: Unspecified |
Comment(by mmetz):
Replying to [comment:10 mmetz]:
to be that the same database is opened twice (once by each driver
instance), which causes database locking, therefore it is not possible to
use one driver instance to fetch records from one table and use another
driver instance to insert records into another table, all in the same
sqlite database.
Now it's possible, the other driver just has to wait a little bit until
the first driver is finished.
Fixed in r45156, r48157, r48158 (7.0, 6.5, 6.4.2, respectively).
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/548#comment:11&gt;
missing database"
      Cpu: Unspecified |
Comment(by mmetz):
Replying to [comment:11 mmetz]:
sqlite database.
Correction, only now (trunk r48333) it's possible. There were more bugs,
both in v.reclass and in the sqlite driver.
A test, within the sqlite mapset of nc_spm_08:
g.copy vect=zipcodes_wake,my_zipcodes_wake
v.dissolve input=my_zipcodes_wake@sqlite layer=1 column=ZIPNAME
output=zip_names
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/548#comment:12&gt;
missing database"
Priority: normal | Milestone: 6.4.3
Component: Database | Version: svn-releasebranch64
      Cpu: Unspecified |
  * version: svn-trunk => svn-releasebranch64
  * milestone: 7.0.0 => 6.4.3
Comment:
Backport of trunk r48333 to GRASS 6.5 in r51261. Can I backport to 6.4 as
well?
The zipcodes_wake example in comment 11 succeeds.
Ticket URL: <http://trac.osgeo.org/grass/ticket/548#comment:13&gt;
missing database"
      Type: defect | Status: closed
Resolution: fixed | Keywords: v.reclass sqlite
  * status: new => closed
  * resolution: => fixed
Comment:
Backported to 6.4 in r52912 by mmetz. Closing.
Ticket URL: <http://trac.osgeo.org/grass/ticket/548#comment:14&gt;
missing database"
Comment(by mmetz):
Replying to [comment:14 neteler]:
That was only the sqlite driver. v.reclass itself is now fixed in r52955.
Ticket URL: <http://trac.osgeo.org/grass/ticket/548#comment:15&gt;
