GDAL
April 9, 2009, 3:10am
1
#550: v.to.3d: column name case sensitive
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: minor | Milestone: 6.4.0
Component: Vector | Version: svn-develbranch6
Keywords: v.to.3d | Platform: Linux
Cpu: x86-32 |
just had need to use v.to.3d for the first time. It's nice!
minor issue: the imported shapefile created columns named as:
INTEGER|cat
DOUBLE PRECISION|EASTING
DOUBLE PRECISION|NORTHING
DOUBLE PRECISION|ELEVATION
(using dbf driver)
I tried to use 'v.to.3d column=elevation' but it exited with the message:
ERROR: Column <elevation> not found in table <bathymetry_point>
It needed to see 'column=ELEVATION'. G_strcasecmp() or tolower() needed?
also that failure left an empty map behind.
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/550> ;
GRASS GIS <http://grass.osgeo.org >
Type: defect | Status: new Priority: minor | Milestone: 6.4.0 Component: Vector | Version: svn-develbranch6 Keywords: v.to.3d | Platform: Linux Cpu: x86-32 | ---------------------+------------------------------------------------------
INTEGER|cat
(using dbf driver)
Are column names case insensitive in all db backends ?
Moritz
Dear all,
I have attached a little patch for v.in.dxf. This just makes a small but
useful addition:
it allows parsing of the 'handle' field which exists for every DXF
entity and provides a way for transporting small bits of data in the DXF
file.
The patch is against the current sources in:
http://trac.osgeo.org/grass/browser/grass/trunk
I am not sure which version of GRASS this should go into,
as it does add a new feature (but really just a tiny one).
Ben
Benjamin Ducke
Senior Geospatial Consultant
Oxford Archaeology
Janus House
Osney Mead
OX2 0ES
Oxford, U.K.
Tel: +44 (0)1865 263 800 (switchboard)
Tel: +44 (0)1865 980 758 (direct)
Fax :+44 (0)1865 793 496
benjamin.ducke@oxfordarch.co.uk
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
(attachments)
v.in.dxf.patch (21.3 KB)
GDAL
July 7, 2009, 7:47pm
4
Resolution: | Keywords: v.to.3d
Platform: Linux | Cpu: x86-32
Comment (by martinl):
Replying to [ticket:550 hamish]:
Fixed in r38297.
Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/550#comment:1> ;
GDAL
July 11, 2009, 9:03am
5
It seems to be related to the db drivers, not v.to.3d.
Ticket URL: <http://trac.osgeo.org/grass/ticket/550#comment:2> ;
GDAL
August 21, 2012, 12:34pm
6
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: closed
Resolution: fixed | Keywords: v.to.3d
Changes (by neteler):
* status: new => closed
* resolution: => fixed
Comment:
The fix has been backported to G6 long time ago, closing.
Ticket URL: <http://trac.osgeo.org/grass/ticket/550#comment:3> ;
