GDAL
April 16, 2009, 6:35am
1
#555: v.in.gpsbabel on wingrass: g.proj error
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: minor | Milestone: 6.4.0
Component: Vector | Version: 6.4.0 RCs
Keywords: v.in.gpsbabel, g.proj | Platform: MSWindows XP
Cpu: x86-32 |
when running v.in.gpsbabel on wingrass (latest 6.4.0svn) a window pops up
that says that g.proj.exe has exited unexpectedly. but then the modules
mostly works fine. (but data is not automatically reprojected to the
current location; it stays in wgs84 lat/lon)
'g.proj -jf' works fine from the wxGUI command prompt thingie.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/555> ;
GRASS GIS <http://grass.osgeo.org >
GDAL
January 24, 2010, 12:42am
2
Resolution: | Keywords: wingrass, v.in.gpsbabel, g.proj
Platform: MSWindows XP | Cpu: x86-32
Changes (by neteler):
* keywords: v.in.gpsbabel, g.proj => wingrass, v.in.gpsbabel, g.proj
Comment:
Does the problem persist with a recent installer from
http://josef.fsv.cvut.cz/wingrass/grass64/ ?
Ticket URL: <http://trac.osgeo.org/grass/ticket/555#comment:1> ;
GDAL
January 24, 2010, 6:37am
3
Comment (by hamish):
Yes, still happens with the6.4.0svn r40456 binary build.
I can confirm that it happens on this line of the script:
OUT_PROJ="`g.proj -jf`"
running that from the MSys terminal prompt works as expected.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/555#comment:2> ;
GDAL
January 24, 2010, 9:39am
4
Comment (by neteler):
Could you try to remove -f from that line in the script? Just to see which
if the "dontprettify" is the problem?
Ticket URL: <http://trac.osgeo.org/grass/ticket/555#comment:3> ;
GDAL
January 24, 2010, 10:57am
5
Still breaks with -f removed. $? is "5".
even if I put "`g.proj -p`" in the script just before the {{{
OUT_PROJ=`g.proj -jf` }}} line that dies with exit code 5 too.
... so what does exit code 5 mean in WinXP?
"`g.proj --help`" in the script does work as expected and exits with
$?==0.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/555#comment:4> ;
GDAL
January 24, 2010, 1:41pm
6
Replying to [comment:4 hamish]:
apparently exit code 5 is "ERROR_ACCESS_DENIED".
http://msdn.microsoft.com/en-us/library/ms681382(VS.85).aspx
It could be for the PROJ_INFO file, but as the program works fine from the
command line I'm not sure what to make it.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/555#comment:5> ;
GDAL
January 25, 2010, 9:39am
7
I would guess that these modules would also be affected-
m.proj
r.in.aster
r.in.wms
r.tileset
v.in.garmin
v.in.geonames
v.in.gns
v.in.gpsbabel
but e.g. m.proj works fine:
#spearfish
g.region -l | grep center
echo "103d45'W 44d26'15N" | m.proj -i
very weird. can anyone else reproduce this bug? my test case is importing
a GPX track file into a lat/long location.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/555#comment:6> ;
GDAL
January 25, 2010, 4:27pm
8
see also #827
Ticket URL: <https://trac.osgeo.org/grass/ticket/555#comment:7> ;
GDAL
March 6, 2010, 11:28pm
9
I am still completely baffled by this one.
why does g.proj consistently fail in one particular script with exit code
5, "ERROR_ACCESS_DENIED", and yet works fine from the MSys command line
and in other scripts?
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/555#comment:8> ;
GDAL
July 6, 2010, 3:26pm
10
Reporter: hamish | Owner: grass-dev@…
Keywords: wingrass, v.in.gpsbabel, g.proj | Platform: MSWindows XP
Cpu: x86-32 |
Comment(by mmetz):
Replying to [comment:8 hamish]:
code 5, "ERROR_ACCESS_DENIED", and yet works fine from the MSys command
line and in other scripts?
Just tested v.in.gpsbabel on a recent (r42640) wingrass installation,
works fine, coordinates are properly reprojected, seems to be fixed.
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/555#comment:9> ;
GDAL
July 10, 2010, 4:40am
11
Type: defect | Status: closed
Resolution: fixed | Keywords: wingrass, v.in.gpsbabel, g.proj
Changes (by hamish):
* status: new => closed
* resolution: => fixed
Comment:
tested on XP using last night's 6.5svn nightly build, imports and
reprojects data fine. I'm not sure why though, there hasn't been a change
to the g.proj code in a year AFAICT. maybe it was the spawn() code or
missing manifest?
still need to retest with 6.4.0, but closing bug as it seems fixed.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/555#comment:10> ;
