[GRASS-dev] [GRASS GIS] #556: ftbfs: g.cairocomp
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 7.0.0
Component: default | Version: svn-trunk
Keywords: g.cairocomp | Platform: Linux
      Cpu: x86-32 |
when building grass 7 I get the following error in g.cairocomp:
main.c: In function 'init_xlib':
main.c:118: error: implicit declaration of function
'cairo_xlib_surface_get_xrender_format'
main.c:118: warning: assignment makes pointer from integer without a cast
make: *** [OBJ.i686-pc-linux-gnu/main.o] Error 1
I have libcairo2-dev version 1.2.4, the fn is not found in
/usr/include/cairo/*.h
This change says that >=1.5.8 is now needed:
http://trac.osgeo.org/grass/changeset/36349
Could a check be added to ./configure to test for
cairo_xlib_surface_get_xrender_format()?
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/556&gt;
      Type: defect | Status: closed
Resolution: duplicate | Keywords: g.cairocomp
  Platform: Linux | Cpu: x86-32
Changes (by hamish):
  * status: new => closed
  * resolution: => duplicate
Comment:
oops, dupe of #419.
closing.
Ticket URL: <https://trac.osgeo.org/grass/ticket/556#comment:1&gt;
