#56: NVIZ. Shrinking of the surface when the surface resolution is increased
(GRASS6.2.3-GRASS6.3)
Reporter: clerici | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: 6.2.3
Keywords: |
When the resolution of the current surface is increased (both in Coarse
Style and in Fine representations), the dimension of the surface is
progressively reduced. [[BR]]
The shrinking can be better evaluated by superimposing a vector map, as in
the attacched examples.[[BR]]
Example 1. Fine resolution =5[[BR]]
Example 2. Fine resolution =10
This happens both in GRASS6.2.3 and GRASS6.3.
Ticket URL: <http://trac.osgeo.org/grass/ticket/56>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
