GDAL
April 18, 2009, 1:30am
1
#561: meta: add a new "normal" bug priority
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
Priority: minor | Milestone: Website
Component: Website | Version:
Keywords: trac | Platform: Unspecified
Cpu: Unspecified |
could a "normal" priority be created in the trac ticket system and be set
as the default?
the default setting of "major" tends to dramatize the priority setting
into irrelevance.
thanks,
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/561> ;
GRASS GIS <http://grass.osgeo.org >
GDAL
April 18, 2009, 11:11am
2
Type: enhancement | Status: closed
Resolution: fixed | Keywords: trac
Platform: Unspecified | Cpu: Unspecified
Changes (by martinl):
* status: new => closed
* resolution: => fixed
Comment:
Done.
Ticket URL: <http://trac.osgeo.org/grass/ticket/561#comment:1> ;
GDAL
May 15, 2009, 3:43am
3
Comment (by hamish):
I would like to request a couple more pre-defined bug reports:
+ open tickets reported by me
+ all tickets modified in the last week
I don't know if the second one is possible, but I thought I'd ask.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/561#comment:2> ;
GDAL
May 15, 2009, 7:22am
4
Comment (by neteler):
re "all tickets modified in the last week":
The "Active ticket" code is
SELECT p.value AS __color__,
id AS ticket, summary, component, version, milestone, t.type AS type,
(CASE status WHEN 'assigned' THEN owner||' *' ELSE owner END) AS owner,
time AS created,
changetime AS _changetime, description AS _description,
reporter AS _reporter
FROM ticket t
LEFT JOIN enum p ON p.name = t.priority AND p.type = 'priority'
WHERE status IN ('new', 'assigned', 'reopened')
ORDER BY p.value, milestone, t.type, time
For trac admins, there is "Copy report" to clone this - then a
modification could be implemented, please suggest.
re "open tickets reported by me" - likewise.
Ticket URL: <https://trac.osgeo.org/grass/ticket/561#comment:3> ;
GDAL
May 15, 2009, 7:37am
5
Replying to [comment:3 neteler]:
... a rather impressive bit of SQL follows ...
AFAIK that can be simply built with existing menus into:
http://trac.osgeo.org/grass/query?status=new&status=assigned&status=reopened&reporter=$OSGEOID
or do those reports require direct SQL into the DB?
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/561#comment:4> ;
