#563: problem with v.in.dxf 3d polyline import
Reporter: vincent | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.5.0
Component: Vector | Version: unspecified
Keywords: dxf 3d | Platform: Unspecified
Cpu: Unspecified |
With v.in.dxf, importing a dxf layer which contains 3d polylines (e.g.
contourlines) results in a "flat" vector map; lines are properly imported
but all line heights are set to 0.
Attached is a test.dxf file (contour lines are stored in layers named cl_m
and cl_s).
Ticket URL: <http://trac.osgeo.org/grass/ticket/563>
