#57: v.digit compilation failure
Reporter: glynn | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.3.0
Component: Python | Version: svn-trunk
Keywords: v.digit v.edit |
v.digit depends upon v.edit but is built before it. The result is that
compilation fails due to the absence of vedit.h (and if it wasn't for the
header, linking would fail due to the absence of libgrass_vedit).
vector/v.edit/lib should be moved to lib/vedit (or maybe lib/vector/vedit)
if it is meant to be used outside of v.edit.
Is there anyway to specify the direct path to vedit.h now that it lives in
/lib/vector/vedit.h ? Not sure if this is a robust approach, but it
compiles. See attached file
Replying to [comment:1 dylan]:
in /lib/vector/vedit.h ? Not sure if this is a robust approach, but it
There are two choices:
If the header is to be public, e.g. because third-party modules may wish
to use vedit.h, it should be installed into $(ARCH_INCDIR) by
lib/vector/vedit/Makefile. See e.g. lib/rst/qtree/Makefile for an example.
The header should then be referenced as <grass/vedit.h>.
If the header (and thus the library) is for internal use only, then leave
it where it is and add e.g.:
EXTRA_CFLAGS = -I../../../lib/vector/vedit
to the Makefile for any module which uses it. The header should be
referenced as just <vedit.h>.
Replying to [comment:2 glynn]:
lives in /lib/vector/vedit.h ? Not sure if this is a robust approach, but
it compiles. See attached file
leave it where it is and add e.g.:
OK- Lets wait and see what the three devs in charge of this module think /
do . In the mean time v.edit does not compile on Debian/Unstable x86
unless some action is taken to better define the location of vedit.h .
I changed the header to be public (it could be also used by QGIS vdigit
port, etc.). I moved vedit.h to 'include' directory. If this solution is
reasonable I will backported the changes to branch for 6.3.
veditlib has been moved to lib/vector/vedit (also backported to
releasebranch_6_3). Seems to be solved, closing the ticket. Martin
