#583: r.watershed: RUSLE factors are wrong for incomplete basins
Reporter: mmetz | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: default | Version: unspecified
Keywords: | Platform: Unspecified
Cpu: Unspecified |
RUSLE factors can not be properly calculated for incomplete (sub-)basins,
but cells with wrong RUSLE factors can only be identified through negative
flow accumulation. Make RUSLE S and LS values for these areas negative as
for flow accumulation?
Related: is there need for slope length output? Slope length is calculated
as internal variable, and it seems that in earlier versions of r.watershed
(GRASS pre-6.x) slope length was an output option.
