[GRASS-dev] [GRASS GIS] #587: WinGRASS: can't open a map for wxDigitizing
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: wxGUI | Version: 6.4.0 RCs
Keywords: wingrass digitize | Platform: MSWindows XP
      Cpu: x86-32 |
(moved here from osgeo4w bug # 37 http://trac.osgeo.org/osgeo4w/ticket/37
because it is seen both in the OSGeo4W and stand-alone installers)
  * wx-vdigit: toolbar comes up but always "No vector map selected for
editing.". In layer list I can choose "Start editing" and a "please wait
while map is opened for editing" message comes up on the bottom status
bar, but the "Stop editing" menu item never ungreys.
tested with both 6.4.0svn binary installers (latest).
both r36287?
Ticket URL: <https://trac.osgeo.org/grass/ticket/587&gt;
  Reporter: hamish | Owner: martinl
      Type: defect | Status: assigned
Resolution: | Keywords: wingrass digitize
  Platform: MSWindows XP | Cpu: x86-32
Changes (by martinl):
  * status: new => assigned
  * owner: grass-dev@lists.osgeo.org => martinl
* cc: grass-dev@lists.osgeo.org (added)
Comment:
It should have been fixed in r36987 (?)
Ticket URL: <https://trac.osgeo.org/grass/ticket/587#comment:1&gt;
      Type: defect | Status: closed
Resolution: duplicate | Keywords: wingrass digitize
Changes (by hamish):
  * status: assigned => closed
  * resolution: => duplicate
Comment:
oh, ok. the installer's help "About GRASS" popup says it is based on
r36287 so just a working off an older build.
sorry for the noise.
H
Ticket URL: <https://trac.osgeo.org/grass/ticket/587#comment:2&gt;
Comment (by hamish):
ps- what'll it take to get the digitizer working for the wingrass builds?
Ticket URL: <https://trac.osgeo.org/grass/ticket/587#comment:3&gt;
Comment (by martinl):
Replying to [comment:2 hamish]:
well, it's revision of wxgui.py not the latest revision of the build.
Which is confusing.
M.
Ticket URL: <https://trac.osgeo.org/grass/ticket/587#comment:4&gt;
Replying to [comment:3 hamish]:
builds?
to fix swig issues;-) Building vdigit/nviz extension is possible. Anyway
they fail because of the swig error.
Ticket URL: <https://trac.osgeo.org/grass/ticket/587#comment:5&gt;
Replying to [comment:4 martinl]:
Which is confusing.
oh, that is rather misleading then. maybe another reason to expedite this
g.version wish:
http://thread.gmane.org/gmane.comp.gis.grass.devel/33031
and/or wrap up ($cleaned$) GIS_H_VERSION into a new grass.py function.
> > wingrass builds?
> possible. Anyway they fail because of the swig error.
this?
http://thread.gmane.org/gmane.comp.gis.grass.devel/32222/focus=28609
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/587#comment:6&gt;
Replying to [comment:6 hamish]:
> function.
with some sort of two element output? (GRASS_VERSION_NUMBER, maybe
GRASS_VERSION_DATE as well)
any ideas how to set GRASS_VERSION_DATE to match time of GIS_H_VERSION
revision? "2009" covers a lot of development ground.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/587#comment:7&gt;
Comment (by glynn):
Replying to [comment:7 hamish]:
#define GIS_H_DATE "$Date$"
Converting it into the desired format will require some processing
commands in configure.in or the Makefiles.
Ticket URL: <https://trac.osgeo.org/grass/ticket/587#comment:8&gt;
Replying to [comment:8 glynn]:
> processing commands in configure.in or the Makefiles.
.... such as | cut -f2 -d'$' ? or do you mean date string format?
Ticket URL: <https://trac.osgeo.org/grass/ticket/587#comment:9&gt;
Comment (by glynn):
Replying to [comment:9 hamish]:
I mean for any format other than the one SVN uses for $Date$.
Ticket URL: <https://trac.osgeo.org/grass/ticket/587#comment:10&gt;
done in r37043. The patch for g.version attached (comments?)
M.
Ticket URL: <https://trac.osgeo.org/grass/ticket/587#comment:11&gt;
Replying to [comment:11 martinl]:
> done in r37043.
any objections to backporting this?
  * keep it easily parsable (on one line), and as backwards compatible as
possible for existing script parsing.
  * (for grass 7 only) s/GRASS/GRASS GIS/
  * flags for diff't info? (only if needed)
  * modify doc/howto_release.txt to say that GRASS_VERSION_DATE should be
manually set to the release day for official releases, and for SVN builds
take it from GIS_H_DATE?
  * append the numeric value portion of GIS_H_VERSION (ie rev #) to
GRASS_VERSION_NUMBER in the g.version output if 'svn' is found in
GRASS_VERSION_NUMBER. so it automatically looks like "6.4.0svn32001"
This way it could be backwards compatible for g6 script parsing.
  * is GRASS_VERSION_UPDATE_PKG relevant anymore for grass >= 5?
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/587#comment:12&gt;
#587: svn versions should better reflect svn rev
      Type: enhancement | Status: reopened
Component: default | Version: 6.4.0 RCs
Resolution: | Keywords: g.version
  Platform: All | Cpu: All
  * status: closed => reopened
  * type: defect => enhancement
  * component: wxGUI => default
  * summary: WinGRASS: can't open a map for wxDigitizing => svn versions
  * platform: MSWindows XP => All
  * keywords: wingrass digitize => g.version
  * resolution: duplicate =>
  * cpu: x86-32 => All
Comment:
hijacked ticket, but the orig was a dud anyway
Ticket URL: <https://trac.osgeo.org/grass/ticket/587#comment:13&gt;
after some more thought and investigation, gis.h's version while useful
isn't as good as it could be (could be unchanged for months, especially in
the stable branch)
  - I propose to add a new -r flag to g.version to display raw
GIS_H_VERSION and GIS_H_DATE strings (no need to shell script style them
AFAICT). This will help people debug situations when the program detects a
libgis/module version mismatch. updated patch attached to this ticket.
either-
  - add an hook script in the svn server to automatically write the present
rev and date to a file in the checkin branch. is that possible without
doubling the rev count? (or setting off an endless loop..). "svnlook
youngest .`" and "`svnlook date .`" might help. see http://svnbook.red-
bean.com/en/1.5/svn.reposadmin.create.html#svn.reposadmin.create.hooks
  - or, modify the main Makefile and add "`svnversion -n .`" somewhere. see
http://subversion.tigris.org/faq.html#version-value-in-source But that
gives the rev of the overall repo, not just the branch we are using.
- so perhaps:
svn log --limit 1 --quiet --xml | grep 'revision=' | cut -f2 -d'"'
37100
svn log --limit 1 --quiet --xml | grep '<date>' | \
   sed -e 's/T.*//' -e 's/.*>//'
2009-05-10
svn log --limit 1 --quiet | grep '(' | \
   sed -e 's/.*(//' -e 's/)$//' | cut -f3,4 -d' '
May 2009
... the goal being that g.version could report like
  GRASS GIS 7.0svn37123 (May 2009)
where the rev number/date was the current branch's latest modification.
This would end up in grass.py as grass.script.revision() or something so
the Help->About window in the GUI could report something accurate.
for formal releases I would guess to skip all the svn stuff and just
hardcode "6.4.0" and "1 May 2009".
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/587#comment:14&gt;
Replying to [comment:14 hamish]:
> 37100
> 2009-05-10
> May 2009
why don't use
svn info
Martin
Ticket URL: <https://trac.osgeo.org/grass/ticket/587#comment:15&gt;
Comment (by jef):
Replying to [comment:15 martinl]:
> why don't use
> svn info
or {{{svnversion}}}
Ticket URL: <https://trac.osgeo.org/grass/ticket/587#comment:16&gt;
thanks for mentioning `svn info`, I hadn't seen that.
However, AFAICT "`svn info`" and "`svnversion`" both give the rev number
of the entire repo, not the latest change to that branch.
using the "`svn log`" method would keep the version unchanged for e.g.
GRASS 5.4.2 since the last time that branch was actually modified.
otherwise all branches+trunk versions change each time any modification is
made globally (e.g. to grass-web or trunk), when in fact they haven't
changed at all.
the downside of `svn log` is that it is rather slow and requires internet
access.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/587#comment:17&gt;
Replying to [comment:17 hamish]:
internet access.
... which probably disqualifies it, not to mention the extra load on the
server.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/587#comment:18&gt;
Comment (by glynn):
see http://subversion.tigris.org/faq.html#version-value-in-source But
that gives the rev of the overall repo, not just the branch we are using.
You need to handle the case of compiling from a snapshot tarball on a
system which doesn't have "svn".
Ticket URL: <https://trac.osgeo.org/grass/ticket/587#comment:19&gt;
