#590: wxGUI vector display forgets layer selection
Reporter: mmetz | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: minor | Milestone: 7.0.0
Component: wxGUI | Version: svn-develbranch6
Keywords: | Platform: Unspecified
Cpu: Unspecified |
When opening properties dialog again, the previously selected layer number
in the selection tab gets replaced by 1 in devbr6 and by blank in trunk.
Other options are remembered. Layer number 1 behaves like -1 in devbr6,
all features are displayed, not only features in layer 1. Works fine in
6.4.0RC4, apart from that layer 1 can be selected even if layer 1 has no
features, but then nothing is displayed (correct in this case).
I used the test vector file of ticket #577 with no features in layer 1, 1
line in layer 3 and 4 points in layer 5.
When I open and then reopen the properties dialog for a vector the layer
number does not change. Maybe I don't quite understand the issue here. I'm
looking at this in the current (21 Sept 2009) version of devbr6 svn.
Replying to [comment:1 cmbarton]:
Hmm, maybe this is a problem of my system? Using current versions of
relbr6 and devbr6 (22 Sept 2009), the layer number still switches back to
1 after a split second if I selected layer 3 or 5 previously. The display
however still shows the correct selection for the previously selected
layer, that only changes after I manually change the layer number.
Can you send me the multi-layer vector file that gives you trouble? I'll test it specifically.
Michael
______________________________
C. Michael Barton
Arizona State University
Tempe, AZ 85287-2402
USA
After import with v.in.ogr, the vector has no features in layer 1, 1 line in layer 3 and 4 points in layer 5.
Markus M
Michael
C. Michael Barton
USA
