#592: wxGUI: allow location wizard to set DMS bounds
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
Priority: normal | Milestone: 6.4.0
Component: wxGUI | Version: 6.4.0 RCs
Keywords: location wizard | Platform: All
Cpu: All |
it would be nice if the location wizard would accept DDD:MM:SS.SSh style
string input like g.region accepts. currently only numeric values are
allowed.
more advanced idea: it could detect if the location is lat/lon or not and
switch to another style with three stacked boxes for D M S values and
radio buttons for N/S, E/W. all three D M S should accept decimal values
and all but D should start empty, not as 0.0.
a negative value for degree would automatically override the radio button.
so the same as g.region (except pad out %02d minutes and sec as needed)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/592>
