[GRASS-dev] [GRASS GIS] #593: WinGRASS GIS.m: cannot select maps from other mapsets
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: Tcl | Version: 6.4.0 RCs
Keywords: wingrass gis.m | Platform: MSWindows XP
      Cpu: x86-32 |
GIS.m on wingrass refuses to let you select maps from another mapset.
e.g. spearfish, from the user1 mapset:
  - start gis.m
  - click the button to add a new raster map
  - click the button at the left of the map name entry box to open the map
list GUI
  - only the user1 folder is open, the PERMANENT folder will not open.
  - type elevation.dem@PERMANENT by hand and it works.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/593&gt;
Resolution: | Keywords: wingrass gis.m
  Platform: MSWindows XP | Cpu: x86-32
Comment (by hamish):
ah, the little [+] [-] boxes to expand the folders are missing on wingrass
for some reason. so the PERMANENT folder stays permanently closed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/593#comment:1&gt;
#593: WinGRASS GIS.m: cannot select maps from mapset GUI
Changes (by hamish):
  * summary: WinGRASS GIS.m: cannot select maps from other mapsets =>
              GUI
Comment:
you can't select maps from the current mapset either. see #637
Ticket URL: <https://trac.osgeo.org/grass/ticket/593#comment:2&gt;
  Reporter: hamish | Owner: marisn
      Type: defect | Status: reopened
* cc: grass-dev@lists.osgeo.org (added)
Ticket URL: <https://trac.osgeo.org/grass/ticket/593#comment:9&gt;
(leave open until everything is backported & job is done)
Ticket URL: <https://trac.osgeo.org/grass/ticket/593#comment:10&gt;
Comment (by marisn):
Thanks Hamish for spotting my oversight with mapset.
$path in select.tcl seems to work just fine without quotes (no idea why -
must be something of tcl beloved lists vs strings), still there was
another issue with running anything if GISBASE contains spaces. Fixed in
r38311. Also an candidate for 6.4.0.
Leaving open till it's tested and backported.
Ticket URL: <https://trac.osgeo.org/grass/ticket/593#comment:11&gt;
Comment (by cmbarton):
Works fine in GRASS 6.4 and 6.5 svn on Mac OS X.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/593#comment:12&gt;
Replying to [comment:12 cmbarton]:
yeah, it's only on WinGrass. I think Maris committed a fix for this in
6.5svn, but it awaits review & backporting by someone who understands Tcl
better than I do.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/593#comment:13&gt;
Hamish
- are sure this is still a problem - I am at home now so I cannot test winGRASS until Monday,
but we have been using winGRASSRC5 for 3 weeks and haven't seen the problem.
maybe somebody with winGRASS on hand can check whether this is still an issue.
Helena
better than I do.
Hamish
grass-dev mailing list
Changes (by cmbarton):
* cc: maris.gis@gmail.com (added)
Comment:
I can't test this on windows unless I have a binary to give to one of my
students who uses windows. I've been out of the loop for awhile. But if
Maris can give me the fix, I can manually insert it into a 6.4 Windows
binary and see if it works.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/593#comment:14&gt;
Comment (by hellik):
grass65 selfcompiled in the osgeo4w-stack on WinVista32
rev39115
nc-dataset
mapset: user1
there's no problem to choose a vector or raster from another mapset like
PERMANENT in the nc-dataset. i've tried this with spaces (C:\gis
data\grassdata) and without spaces (C:\gisdata\grassdata) in the path to
the location.
Ticket URL: <http://trac.osgeo.org/grass/ticket/593#comment:15&gt;
cannot test winGRASS until Monday, but we have been using
It is with the tcltk/gis.m GUI, not the wxpython GUI.
Hamish
Replying to [comment:15 hellik]:
> rev39115
> nc-dataset
> mapset: user1
the location.
tested in the tcltk/gis.m GUI
Ticket URL: <http://trac.osgeo.org/grass/ticket/593#comment:16&gt;
Is this relevant anymore? If the problem is
1) with the TclTk GUI and not wxpython,
2) only in Windows, and
3) if wxpython is the default GUI for WinGRASS 6.4,
do we need to worry about it?
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/593#comment:17&gt;
Replying to [comment:17 cmbarton]:
To me, yes. Others are of course free to decide that for themselves and
spend their time worrying about issues they find more interesting, as they
like.
bugs we know about should be fixed. especially ones that cripple an entire
subsystem. anyway, this is just a small backport, not a huge investment
in/redirection of effort. The larger problem on spaces in path names is of
course another matter. I'm still a bit frustrated that the MSys devs won't
even take patches for this class of bug.
I would also note that making things more robust on WinGrass typically has
the byproduct of making thinks slightly more robust on other platforms as
well.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/593#comment:18&gt;
If it's just a backport, I'm definitely in favor doing this.
Like I said, I can probably stick a TclTk patch into a student's 6.4
Windows binary to test this if it is a help. To do this on Windows,
however, it will be much easier if I get the entire patched tcltk module
instead of a patch file.
Michael
Ticket URL: <https://trac.osgeo.org/grass/ticket/593#comment:19&gt;
Please test r39149.
Ticket URL: <http://trac.osgeo.org/grass/ticket/593#comment:20&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: wingrass gis.m
  * status: reopened => closed
  * resolution: => fixed
Comment:
tested in latest WinGrass 6.4 installer (WinGRASS-6.4.0SVN-
r39271-1-Setup.exe).
works; closing bug.
(it complains that it can't find the fontcap file though)
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/593#comment:21&gt;
