[GRASS-dev] [GRASS GIS] #596: provide a grass-config script
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
Component: Installation | Version: svn-trunk
Keywords: | Platform: All
      Cpu: All |
fwd from gdal's tracker:
"Grass enhancement request : it would be cool if GRASS had a grass-config
script."
https://trac.osgeo.org/gdal/ticket/2953#comment:2
Ticket URL: <https://trac.osgeo.org/grass/ticket/596&gt;
Resolution: | Keywords:
  Platform: All | Cpu: All
Comment (by neteler):
A grass-config would probably facilitate the development of an automated
GRASS-Addons integration script (which downloads Addon from SVN, then
compiles it according to the local settings)
Ticket URL: <https://trac.osgeo.org/grass/ticket/596#comment:1&gt;
Resolution: | Keywords: gdal-plugin
Changes (by hamish):
  * keywords: => gdal-plugin
Comment:
idea for how this could be done:
write a GRASS_BATCH_FILE which would start grass in a dummy location and
run a single `g.version -b` command, then exit.
(add new flags to g.version as needed for the info you want)
or probably much simpler to just write a script which parses
$GISBASE/include/Make/* as needed.
gdal-config has:
Usage: gdal-config [OPTIONS]
Options:
         [--prefix[=DIR]]
         [--libs]
         [--dep-libs]
         [--cflags]
         [--datadir]
         [--version]
         [--ogr-enabled]
         [--formats]
which of those would be useful in a grass-config? (obviously not the last
two)
any additional requests for options?
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/596#comment:2&gt;
Comment (by glynn):
Replying to [comment:1 neteler]:
Add-ons should get all the configuration information they need from the
*.make files.
Replying to [comment:2 hamish]:
Parsing *.make won't work; given that values can be arbitrary make
expressions, you would need to duplicate make's functionality exactly.
You would be better off just invoking make on a suitable Makefile, e.g.:
$ cat foo.mk
MODULE_TOPDIR = $(GISBASE)
include $(MODULE_TOPDIR)/include/Make/Vars.make
var.%:
         @echo $($*)
$ make -f foo.mk var.PNGLIB
-lpng -lz -lm
> gdal-config has:
[snip]
last two)
None of them, really. GRASS isn't a single library; you would need
separate options for each component.
Ticket URL: <https://trac.osgeo.org/grass/ticket/596#comment:3&gt;
Reporter: hamish | Owner: grass-dev@…
Keywords: gdal-plugin | Platform: All
      Cpu: All |
Changes (by wolf):
* cc: wolf (added)
Comment:
The file grass-config.patch adds a basic version of what grass-config
could be. Note that it uses the configured values of /prefix and so on to
figure out where GRASS has been installed. Applies to trunk. This can be
expanded to have more options or more varied options...
Ticket URL: <https://trac.osgeo.org/grass/ticket/596#comment:4&gt;
      Cpu: All |
Comment(by dylan):
I think that there is a typo in the patch as submitted: "--restlibs"
should be "--rastlibs".
Ticket URL: <https://trac.osgeo.org/grass/ticket/596#comment:5&gt;
