[GRASS-dev] [GRASS GIS] #597: Digitize tool won't work
Reporter: vince | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: default | Version: 6.4.0 RCs
Keywords: digitize | Platform: MacOSX
      Cpu: x86-64 |
When I launch the digitize tool under wxpython GUI, all seems to be fine
(buttons appears, I can select a layer with the combo box, etc.), but when
I click for the first time (or any time after), I have a "no layer
selected for editing" error message. In other words: I can't digitize
nothing!
Ticket URL: <http://trac.osgeo.org/grass/ticket/597&gt;
  Reporter: vince | Owner: martinl
      Type: defect | Status: assigned
Component: wxGUI | Version: 6.4.0 RCs
Resolution: | Keywords: digitize
  Platform: MacOSX | Cpu: x86-64
Changes (by martinl):
  * status: new => assigned
  * owner: grass-dev@lists.osgeo.org => martinl
  * component: default => wxGUI
* cc: grass-dev@lists.osgeo.org (added)
Comment:
OK, I did you select any vector layer for editing or created new one?
Ticket URL: <http://trac.osgeo.org/grass/ticket/597#comment:1&gt;
Comment (by vince):
Both. Neither does work.
In the README of the RC4 version, it is written (I have discovered that
afterwards) that digitize won't work in 64-bit mode. I can't figure if it
won't work or it won't compile. If the former, then my ticket is maybe
purposeless; if the latter, then it is wrong, since I have a v.digitize
module installed for both x64 and i386 archs. Yet, I get the GUI addition
all right, so it's bizarre.
Ticket URL: <http://trac.osgeo.org/grass/ticket/597#comment:2&gt;
Comment (by kyngchaos):
vdigit in the wxGUI is python-based. It won't compile or run for 64bit
OSX. But, even when the rest of GRASS is 64bit, vdigit (and wx nviz) will
compile and run for 32bit OSX.
v.digit (vector/v.digit) will compile 64bit, since it's not python-based.
I don't see anything in the README that says it won't run on 64bit OSX
(unless you mean the macosx/readme.rtf), but it's possible and very likely
- there were problems in the vector dglib for OSX 64bit that have been
fixed in trunk, but I don't know if they were backported, since the fix
was indirectly a result of another bugfix.
Ticket URL: <http://trac.osgeo.org/grass/ticket/597#comment:3&gt;
Comment (by vince):
Okay, so if I am not mistaken, I made a confusion between vdigit and
v.digit. Apologies.
Yes, I meant the macosx/readme.rtf, sorry for being a bit unspecific.
So, the best is maybe that I fetch the SVN version and retry. I am a bit
reluctant to propose a svn-based macport, but if it has special fixes for
OS X that are not available in the main release, it can make sense.
Ticket URL: <http://trac.osgeo.org/grass/ticket/597#comment:4&gt;
... I just dug around for the details (need to dust off the cobwebs in my
memory) - looks like the bug was fixed in February, and I verified it.
trunk r36003 and devbr6 r36049. BUT, it appears this didn't make it into
release 6.4.
It would be nice to get this into 6.4, but it might be too late. Maybe
6.4.1? If that is not going to happen, then I'd say that GRASS 6.4 is
still not ready for 64bit OSX.
Ticket URL: <http://trac.osgeo.org/grass/ticket/597#comment:5&gt;
... for reference: it's bug #431.
Ticket URL: <http://trac.osgeo.org/grass/ticket/597#comment:6&gt;
Comment (by vince):
Ok, fine thanks a lot and sorry for the inconvenience. I'm going to alter
the port to fetch the svn version instead, at least until a stable version
with correct 64-bit OS X support is released. Anyhow, a full 64-bit build
will not be possible until Wxwidgets itself is 64-bit safe, that is the
Cocoa port is finished. At that time, only Qgis offer full 64-bit mode
under OS X, since Qt 4.5 moved to Cocoa.
Thanks again
Ticket URL: <http://trac.osgeo.org/grass/ticket/597#comment:7&gt;
Comment (by hamish):
Replying to [comment:5 kyngchaos]:
> cobwebs in my memory) - looks like the bug was fixed in February,
> and I verified it. trunk r36003 and devbr6 r36049. BUT, it
> appears this didn't make it into release 6.4.
> Maybe 6.4.1? If that is not going to happen, then I'd say that
> GRASS 6.4 is still not ready for 64bit OSX.
it has been in 6.5svn for 3 months (apparently) without problems, so for
my vote I'd say go ahead and risk the backport for 6.4.0.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/597#comment:8&gt;
...It appears it has been backported already to 6.4 release (r36838), it
was just too late for the rc4 tarball. So this v.digit 64bit sidetrack is
taken care of.
Ticket URL: <http://trac.osgeo.org/grass/ticket/597#comment:9&gt;
Comment (by vince):
It still does not work in RC5…
Ticket URL: <http://trac.osgeo.org/grass/ticket/597#comment:10&gt;
Well, I found that if I select "Digitize" from the toolbar popup on the
display window, I get the same "no layer selected" error. But if I right-
click a vector layer in the layer manager and "Start editing", digitizing
works.
Ticket URL: <http://trac.osgeo.org/grass/ticket/597#comment:11&gt;
Comment (by cmbarton):
Still broken in 6.4.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/597#comment:12&gt;
Works for me in 6.4 and 6.5 on the Mac. Can anyone confirm that this is
still broken after William changed the way this is compiled on a Mac?
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/597#comment:13&gt;
Priority: normal | Milestone: 6.4.2
      Cpu: x86-64 |
  * milestone: 6.4.0 => 6.4.2
Ticket URL: <http://trac.osgeo.org/grass/ticket/597#comment:14&gt;
      Cpu: x86-64 |
Comment(by martinl):
please try recent 6.4.2 from SVN...
Ticket URL: <http://trac.osgeo.org/grass/ticket/597#comment:15&gt;
      Cpu: x86-64 |
Comment(by cmbarton):
The wxDigitizer now seems to work fine in GRASS 6.4.2 (assuming it is
installed and activated.). No crash when making point, line, area.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/597#comment:16&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: digitize
  * status: assigned => closed
  * resolution: => fixed
Ticket URL: <http://trac.osgeo.org/grass/ticket/597#comment:17&gt;
