some Italian users notice that r.li modules are not active in GRASS
GIS 6.4.4 on windows, is this correct?
On the GRASS GIS 6.4.4 release announce there is "release include a
complete rewrite of the r.li suite"
you are right, I would thought that author of r.li.* updates checked
also availability on Windows. I will try to check what is wrong with
the installer.
On 27 June 2014 16:11, Martin Landa <landa.martin@gmail.com> wrote:
Hi
the installer.
the installer.
r.li modules are not simply built on Windows [1]. Any idea why? Martin
On Fri, Jun 27, 2014 at 10:41 AM, Martin Landa <landa.martin@gmail.com>
wrote:
2014-06-27 16:36 GMT+02:00 Luca Delucchi <lucadeluge@gmail.com>:
>> the installer.
I don't know but I hope that the authors discovered by svn blame know.
Anyway, blame is such a funny name for a command. Trac's annotate is boring.
yes, the old r.li.* daemon/worker system required unix sockets, and
so would only work in the cygwin build. We never figured out how to
properly support those natively on MS Windows. I believe in the new
backported version of r.li those things are all removed now so it could
have the conditional removed from the Makefile and the modules tested
in a nightly WinGrass build. If it works I'd suggest a setup_6.4.4-2.exe
release be prepared with an altered Makefile. The source code isn't
touched so it wouldn't introduce any platform dependent behavior which
would need a new point release, instead it would only reduce platform
differences.
Luca:
that's all of us; especially big jobs need many testers to check
all angles.
r.li modules enabled in grass64 in r61153. Please test next build of
grass64-dev (no.13). Martin
Martin:
Thanks. I am unable to test for the next weeks, but would appreciate if
someone else could try it.
Martin:
regards,
Hamish
grass-dev mailing list
couldn't execute "printenv": no such file or directory
while executing
"exec printenv HOME"
invoked from within
"set env(HOME)[exec printenv HOME]"
(file
"C:\OSGeo4W\apps/grass/grass-6.4.5svn/etc/r.li.setup/r.li.setup.main"
line 27)
I am getting the same dialog on Linux when launching the module from
menu. When launching the module from wxGUI command line I am getting
different dialog (Tcl/Tk configuration tool). Martin
launching the module r.li.setup from wxGUI command line, an error message
pops up (already mentioned in this thread):
while executing
invoked from within
(file
line 27)
with r.li.setup --ui, the empty r.li.setup-wxgui pops up.
although the path to the conf file is given, it seems it's hard coded where
the r.li.*-module looks for the conf file (see doubling the path in the
error message)
manually creating the .r.li-folder where the module looks for and manually
putting there the conf file, the r.li.*-module is working:
error message)
