#604: /usr/lib/grass64/etc/grass-run.sh does not work properly when called by
gis.m to execute in a external xterm
Reporter: frankie | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: minor | Milestone: 6.4.0
Component: default | Version: unspecified
Keywords: | Platform: Linux
Cpu: Unspecified |
PATH=<grass>/bin:<grass>/scripts:$PATH prepending is missing: that causes
not found errors for all grass commands. Of course it works correctly when
called within the main terminal window because the PATH is properly
initialized before.
If you wish to resize the X monitor, do so now. Window size is
locked while interactive modules are running.
/usr/lib/grass64/etc/grass-run.sh: line 29: g.proj -p: command not found
ERROR: g.proj -p exited abnormally. Press <enter> to continue.
Ticket URL: <http://trac.osgeo.org/grass/ticket/604>
