[GRASS-dev] [GRASS GIS] #607: Spinboxes should be used for r.composite params
Reporter: frankie | Owner: grass-dev@lists.osgeo.org
Priority: minor | Milestone: 6.4.0
Component: Tcl | Version: 6.4.0 RCs
Keywords: | Platform: Unspecified
      Cpu: Unspecified |
The Tk interface should use a spinbox widget instead of a bogus int value
in r.composite for levels. This is exactly what's done in the wx
interface, so there's no reason to use a different paradigm (which is
quite confusing for a naive user). This could also be true for other
modules...
Ticket URL: <http://trac.osgeo.org/grass/ticket/607&gt;
  Priority: minor | Milestone: 6.5.0
Resolution: | Keywords:
  Platform: Unspecified | Cpu: Unspecified
Changes (by hamish):
  * milestone: 6.4.0 => 6.5.0
Comment:
enhancements which touch core code -> 6.5
Ticket URL: <https://trac.osgeo.org/grass/ticket/607#comment:1&gt;
      Type: enhancement | Status: closed
Resolution: wontfix | Keywords:
Changes (by cmbarton):
  * status: new => closed
  * resolution: => wontfix
Comment:
The wxpython interface and way of parsing GRASS command arguments is much
more sophisticated than the much older one for TclTk. It would take a
major rewrite of the venerable gui.tcl to add a lot of these new features
and would probably also require that the tcltk output of g_parser be
substantially improved (wxpython reads xml from g_parser). Given that we
are switching interfaces after 6.4 or the 6.x series, I don't think that
this is worth the effort.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/607#comment:2&gt;
