[GRASS-dev] [GRASS GIS] #61: vdigit makefile uses hardwired compile and link flags
Reporter: kyngchaos | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Python | Version: 6.3.0 RCs
Keywords: |
The vdigit makefile has some compile and link flags that should be left up
to configuration.
CXXFLAGS has "-c -fpic". fpic is fPIC on OSX (fpic is invalid for OSX).
-c is handled in the GRASS object make rules.
LDFLAGS has "-shared -fpic". -shared is platform-specific, and is not the
correct flag for OSX.
If the GRASS make rules can't be used for vdigit, then at least its
compile and link rules should more closely mirror the GRASS default rules
to pick up platform configuration values.
Ticket URL: <http://trac.osgeo.org/grass/ticket/61&gt;
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
Resolution: | Keywords:
Comment (by neteler):
I have changed -fpic to ${SHLIB_CFLAGS} (see r30332).
Still -shared is there.
Ticket URL: <http://trac.osgeo.org/grass/ticket/61#comment:1&gt;
Comment (by kyngchaos):
Some more notes:
On OSX, the proper linking for a python extension is -bundle, not
-dynamiclib. So "-shared" should be replaced by some configured value in
Platform.make.
Shouldn't COMPILE_FLAGS_CXX be in CXXFLAGS, and LINK_FLAGS in LDFLAGS?
Also, with COMPILE_FLAGS_CXX and LINK_FLAGS, on OSX that's where the arch
flags end up. On 64bit OSX Leopard, wxPython is not available in 64bits
due to limitations in the system, so if one is trying to build 64bits,
vdigit linking will fail. This will strip out any 64bit flags (if they
are the only arch flags, it's OK because the default arch is 32bits on
OSX):
CXXFLAGS = -c ${SHLIB_CFLAGS} $(subst -arch ppc64,$(subst -arch
x86_64,${COMPILE_FLAGS_CXX})) \
-I$(ARCH_DISTDIR)/include $(GDALCFLAGS) $(PYTHONCFLAGS)
$(WXWIDGETSCXXFLAGS)
LDFLAGS = -bundle ${SHLIB_CFLAGS} $(subst -arch ppc64,$(subst -arch
x86_64,${LINK_FLAGS})) \
-L$(ARCH_LIBDIR) $(VECTLIB) $(GISLIB) $(GDALLIBS) $(VEDITLIB)
$(WXWIDGETSLIB) $(PYTHONLDFLAGS) -lgdi
See ticket #58 for info about linking _gdi_.so.
Ticket URL: <http://trac.osgeo.org/grass/ticket/61#comment:2&gt;
Comment (by martinl):
Replying to [comment:2 kyngchaos]:
Platform.make.
I removed from Makefile some hardcoded flags and also added
COMPILE_FLAGS_CXX and LINK_FLAGS (which are contained in CXXFLAGS and
LDFLAGS, see Grass.make) -- r30523.
_gdi_.so is still directly linked into _grass6_wxvdigit.so. When I remove
-lgdi from LD_FLAGS 'import grass6_wxvdigit' fails
_grass6_wxvdigit.so: undefined symbol: _ZN10wxPseudoDC9AddToListEP5pdcOp
Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/61#comment:3&gt;
SHLIB_LDFLAGS is probably meant to be SHLIB_LD_FLAGS? Though this is
empty for OSX.
Configure still needs to determine proper linking flags for a python
extension (-shared/-bundle), which may be different from library linking,
and set some platform.make variable, or add it to PYTHONLDFLAGS.
Ticket URL: <http://trac.osgeo.org/grass/ticket/61#comment:4&gt;
Comment (by hamish):
fyi removed (or at least shifted) hardcoded SWIG=swig back into
./configure, r30525.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/61#comment:5&gt;
Just taking a look at the latest incarnation of the makefile - SHLIB_LD
can't be used for linking the module.so. This contains the dynamic/shared
lib flag, which is not correct for a python extension on OSX, and contains
the version and install_name flags meant for a GRASS library and are not
valid for the -bundle flag needed here.
Would it be possible to configure a PYTHON_LD for use in this case?
Ticket URL: <http://trac.osgeo.org/grass/ticket/61#comment:6&gt;
Comment (by glynn):
Replying to [comment:6 kyngchaos]:
Possible? Yes. Straightforward? No.
Look at the SC_CONFIG_CFLAGS macro in aclocal.m4, which defines SHLIB_LD.
You would need to add a corresponding PYTHON_LD macro for each platform.
We can't just use "$(CC) $(PYTHONLDFLAGS)", as "python-config --ldflags"
doesn't include the -shared flag on Linux (where it is definitely
required).
Ticket URL: <http://trac.osgeo.org/grass/ticket/61#comment:7&gt;
There is distutils. Build it with distutils, and it will be compiled and
linked correctly for each platform. The problem with this is that it
builds locally into a folder with a platform-specific name chosen by
distutils (ie build/lib.macosx-10.5-i386-2.5), so the makefile would not
know where it is to install it in the GRASS dist folder. But it looks
like there are build options to force a build dir name, so it would
something known to the makefile.
That would mean creating a setup.py for the compile step.
Ticket URL: <http://trac.osgeo.org/grass/ticket/61#comment:8&gt;
Comment (by glynn):
Replying to [comment:8 kyngchaos]:
and linked correctly for each platform. The problem with this is that it
There are other Makefile integration issues, e.g. specifying the compiler,
compilation switches, etc. Also, we don't want to re-compile files which
haven't changed; that could become a significant issue for developers as
the code grows.
More generally, I don't like the idea of invoking commands where no-one
understands what's going on under the hood (this is why we don't use
libtool). And, AFAIK, no-one here understands the internals of distutils.
If there is some way to get distutils to tell us which flags we should use
(i.e. act like a working version of python-config), that would be
preferable.
Also, as it stands, we currently don't know how to invoke Python on the
setup.py file (configure currently detects python-config, not python).
Ticket URL: <http://trac.osgeo.org/grass/ticket/61#comment:9&gt;
You could look at GDAL for an example of configuring and running
distutils. Also, the old python bindings in GDAL (ogpython, in the pymod
dir) used a manual-compile method that could be of use. But distutils is
standard stuff for python, so we shouldn't be afraid to use it.
If we don't use distutils, for whatever reason, we're stuck with trying to
configure some form of PYTHON_LD, like in the GDAL ogpython.
Ticket URL: <http://trac.osgeo.org/grass/ticket/61#comment:10&gt;
Replying to [comment:9 glynn]:
> should use (i.e. act like a working version of python-config),
> that would be preferable.
> on the setup.py file (configure currently detects python-config,
> not python).
maybe some hints here:
   source:grass/trunk/swig/python/NumPtr/setup.py
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/61#comment:11&gt;
Component: wxGUI | Version: 6.3.0 RCs
Changes (by martinl):
  * component: Python => wxGUI
Ticket URL: <http://trac.osgeo.org/grass/ticket/61#comment:12&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
  Platform: Unspecified | Cpu: Unspecified
  * status: new => closed
  * platform: => Unspecified
  * resolution: => fixed
  * cpu: => Unspecified
Comment:
Currently are wxGUI C++ extensions built with setup.py. Closing the
ticket.
Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/61#comment:13&gt;
