[GRASS-dev] [GRASS GIS] #610: r.sun: incidout uses 0 instead of NULL
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: normal | Milestone: 6.5.0
Component: Raster | Version: 6.4.0 RCs
Keywords: r.sun | Platform: All
      Cpu: All |
r.sun(2)'s incidout= output map uses 0 instead of NULL for shadowed areas
which have no direct line of sight to the sun. This harms any sort of
numerical analysis on the output because it biases towards zero, and makes
the creation of MASKs harder.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/610&gt;
Resolution: | Keywords: r.sun
  Platform: All | Cpu: All
Comment (by neteler):
... but it uses G_set_f_null_value():
http://trac.osgeo.org/grass/browser/grass/trunk/raster/r.sun2/main.c#L1221
Ticket URL: <https://trac.osgeo.org/grass/ticket/610#comment:1&gt;
Comment (by mmetz):
... but what about
http://trac.osgeo.org/grass/browser/grass/trunk/raster/r.sun2/rsunlib.c#L439
shouldn't that be
return UNDEFZ;
A wild guess.
Ticket URL: <http://trac.osgeo.org/grass/ticket/610#comment:2&gt;
Comment (by hamish):
test case:
G65> g.region -d # spearfish: 44:30N 477x634
G65> r.surf.volcano out=gauss method=gaussian kurtosis=1
just after sunrise on a frosty winter's morn
G65> r.sun -s elevin="gauss" incidout="day355rad.inci.08hr" \
   day=355 time=8.00
note '''western boundary cells are all NULL''' (!??) and no other:
G65> r.univar day355rad.inci.08hr
  100%
total null and non-null cells: 302418
total null cells: 477
Of the non-null cells:
n: 301941
minimum: 0
maximum: 2.85292
range: 2.85292
mean: 2.35481
mean of absolute values: 2.35481
standard deviation: 1.04271
variance: 1.08725
variation coefficient: 44.2802 %
sum: 711013.3009517193
real data range is 2.7-2.8deg above horizon
note large number of 0.0 cells:
G65> r.stats day355rad.inci.08hr nsteps=10 -c
  100%
0-0.011188 49481
2.752233-2.763421 695
2.763421-2.774609 33611
2.774609-2.785797 29075
2.785797-2.796985 27769
2.796985-2.808173 34948
2.808173-2.819361 42280
2.819361-2.830549 43446
2.830549-2.841737 40635
2.841737-2.852925 1
* 477
work-around:
r.null day355rad.inci.08hr setnull=0.0
then you get nice d.histogram output, etc.
> shouldn't that be
> return UNDEFZ;
> ? A wild guess.
no luck; same result.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/610#comment:3&gt;
correction, the above r.stats output is the result of:
G65> r.stats day355rad.inci.08hr nsteps=255 -c
range bins containing no cells are not printed in the output (even though
-n,-N flags are not given)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/610#comment:4&gt;
Comment (by mmetz):
Next try. IIUR, incidout is calculated in rsunlib.c by lumcline(). For a
shadowed area, sunVarGeom->isShadow is apparently set to 1 and incidence
is left as 0. For an area where there is still night, incidence angle is
negative and set to 0 (r.sun2/rsunlib.c#L439). That's why my first wild
guess didn't work, it was probably setting night to NULL, not shadow. If
any of the input maps is NULL, incidence (as all other output maps) is set
to NULL (says the manual). To keep a maximum of information in the
incidence output map, you could e.g. set incidence of shadows to -1, make
night -2, keep special case incidence == 0 with no shadow, and propagate
any input NULL cells as NULL cells. Then optionally use r.null to set
shadows and/or night to NULL. Or discard all this info and make input NULL
cells, night, shadow and special case incidence == 0 with no shadow all
NULL (if (s <= 0) return UNDEFZ;)
Not tested, all interpreted from the code and the manual.
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/610#comment:5&gt;
Since trac sucks again today, here the manual copy-paste from the ticket
for this list:
05/22/09 05:39:21 changed by neteler
I contacted Jaro:
On Fri, May 22, 2009 at 11:09, Jaro Hofierka wrote:
   ... I believe that it is in rsunlib.c in lumcline2() function. If s < 0 (shadow) it returns 0, what in fact should be null.
  Also please note that the s variable in lumcline() is initiated to 0.
       double s = 0;
   (this covers also other causes of shadows)
   So what is returned from the lumcline() as 0 should be written as null in the output.
Comment (by mmetz):
Replying to [comment:6 neteler]:
> I contacted Jaro:
     double s = 0;
in
> > the output.
As simple as
if (s <= 0)
     return UNDEFZ;
in trunk/raster/r.sun2/rsunlib.c#L438 - #L439 ?
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/610#comment:7&gt;
Replying to [comment:7 mmetz]:
> As simple as
  if (s <= 0)
      return UNDEFZ;
yes, as simple as that!
now, any ideas about why the western most column is all nulls? consequence
of not supplying aspect/slope maps??
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/610#comment:8&gt;
Replying to [comment:8 hamish]:
> consequence of not supplying aspect/slope maps??
weird, if I zoom in to be entirely within elevation.dem, then run with
slope=slope and aspect=aspect, now the southern most row and eastern most
column are not NULL. I guess that's just because those two edges have only
NULL between them and the sun rising in the south-east that day, so no way
of knowing that they're on a downslope or not.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/610#comment:9&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: r.sun
Changes (by hamish):
  * status: new => closed
  * resolution: => fixed
Comment:
fixed in r38184 etc. with patch from Thomas Huld.
Ticket URL: <https://trac.osgeo.org/grass/ticket/610#comment:10&gt;
